Strange Leak - SailNet Community
Blogs
Go Back   SailNet Community > General Interest Forums > Gear & Maintenance > Diesel Engine Forum
Diesel Engine Forum This is a new forum dedicated to diesel engines and their applicable accessories.
Old 07-13-2009
ahalfon is on a distinguished road
Strange Leak
I have a Yanmar 2GM20 on my Pearson 28, which has been working fairly well for the three years I owned the boat. It initially had a leaking water pump which I replaced last year. I then noticed it also had a fuel leak, and had to replace the secondary fuel filter assembly and tighten the screws on the fuel pump and line connector.
Now that the major leaks are fixed, I noticed a small amount of liquid accumulating in the pan under the engine, which has a sharp acetone/alcohol smell. Any ideas where it might be coming from or what it is?
Thanks in advance,
Amir
Old 07-13-2009
Don Radcliffe
donradclife is on a distinguished road
Coolant/antifreeze??
Old 07-14-2009
certainly a possibility, but it looks clear rather than green
Old 07-14-2009
timebandit's Avatar
timebandit is on a distinguished road
Battery acid?
Rick
Mac 25
Copernicus
Southern California
I am not a prejudice racist sexist bigot. I just hate stupid people.
Old 07-14-2009
The battery is located in a different (enclosed) area.
Old 08-18-2009
flatracker is on a distinguished road
If it is a 2GM20
there is no anti-freeze coolant in it. A 2GM20 is raw water cooled. If a 2GM20F, which is fresh water cooled, then you have anti freeze. But those engines are pretty rare.
Sounds like coolant or raw water except for the smell. If you buy your fuel from a non marina type supply, then it is fairly clear.
Dream like you will live forever. Live like you will die tomorrow. ( James Dean )
Old 08-18-2009
RichH's Avatar
RichH will become famous soon enough
Take a GOOD look at your raw water pump, as there is a 'weep hole' in the housing portion of the shaft .... and it will drip out into the boat when the seal on the shaft wears out needs replacing.
Also examine the exhaust manifold and engine block casting ... as sometimes these can develop 'pin hole' leaks when the 'internals' become corroded. Such pin hole corrosion is accelerated in engines that are 'stored long term' with all the water drained out of them.
Old 08-18-2009
Irrationally Exuberant
arf145 is on a distinguished road
Funny, but I just ran into this with my 2GM20F. Had a little clearish, slightly oily fluid in the drip pan under the engine. I puzzled over it, even though there are only so many fluids in there--oil in the crankcase (no, this was too clean), oil in the tranny (no, this was a bit thin), antifreeze (no). Finally I thought diesel fuel, having forgotten that I use road fuel not red marine fuel. Had a slight drip where the fuel hose connects to the engine.
arf145
1987 Pearson 28-2
Chesapeake Bay
Shaft Log Leak (Pics) nk235 Gear & Maintenance 31 05-06-2009 07:32 PM
Ground leak? patja Gear & Maintenance 7 09-24-2008 10:36 AM
When a rudder bearing is bad, can it cause a leak? rryan14 Gear & Maintenance 5 05-19-2008 06:17 AM
Propane leak brak Gear & Maintenance 34 10-18-2007 03:39 PM
Yanmar Fuel Leak jnj Gear & Maintenance 3 07-19-2005 01:41 AM
SEO by vBSEO 3.6.0
(c) Sailnet 2000-2006
