Go Back   SailNet Community > General Interest Forums > Gear & Maintenance > Diesel Engine Forum
Diesel Engine Forum This is a new forum dedicated to diesel engines and their applicable accessories.
  #11 (permalink)
Old 08-14-2009
trantor12020's Avatar
trantor12020 is on a distinguished road
I get this problem when I sailed for long period on port tack at >40deg heel. apparently the water intake ocassionally is out of water and water drains out causing air trap. filling up the pump discharge hose solve the problem each time.
Ken
2002 Hunter 326, SV Millennium 2
1999 Macgregor 26X, SV Millennium
  #12 (permalink)
Old 08-15-2009
L124C's Avatar
L124C is on a distinguished road
Why would you be sailing for long periods at 40 degrees? Think it's probably time to reduce sail. You might actually move forward as opposed to sideways Generally, I think anything much over 20 degrees is excessive. Hard on the boat, sailors and counter productive. Anyway, I certainly didn't have the intake out of the water
  #13 (permalink)
Old 08-15-2009
well, its not often we get such a breeze here so we kinda enjoy it. we hardly even reef our sails here too. just let it out if wind gets too strong. anything more 25kts is probably couple times per year only.
Ken
  #14 (permalink)
Old 08-15-2009
Northeaster is on a distinguished road
Did you use a new (or the old) paper gasket t oseal the cover on the pump.
If so, take it off, and try a bit of RTV silicone sealant (auto parts store). You want only a little sealant, as too much ( or a buildup of old paper gaskets, etc) will cause the cover to sit too far from the impeller, and it won't pull as much water.
Did you reuse the old cover? Was it scored?? If so, clean the other sit and flip it over.
I used to have the exact some trouble as you. Had to close the engine seacock while sailing, to prevent water from running out / air pulling in (maybe from the exhaust). Turned over scored cover to other side, and it;s been perfect.
You could also have an airleak in the new hose / clamps.
Sailing / water rushing past hull will cause (venturi effect, I believe) the water in the through hull and hoses to ne "pulled" out, if it can be replaced ny air squeezing by the pump / cover plate, oe anothre source (airleak in hoses)
  #15 (permalink)
Old 08-17-2009
L124C's Avatar
QUOTE=rikhall]Hey
OK - similar problem I have. New to us boat - a 1980 Irwin Citation 34
Motors perfectly - always starts, always spits water.
Twice - sailed and then when starting the engine hot light soon came on and no water was coming out.Both times, took the hose off, looked at the impeller - everything seemed fine.Let it cool - started it up and everything was fine.
Uggg! If you come up with a solution - let me know.
Rik
Hi Rik:
If you look back at the post, I found the problem was me! However someone responded who heeled over so far it exposed his intake and allowed air in (though, someone else stated the pumps are self priming) On some boats big seas might also do it . If air is getting in your intake, I think opening the line at the impeller (as you did) would allow the air to bleed out (but then, I'm no mechanic!). If this was the cause, closing the intake while sailing would cure it. BTW, whenever I close the intake valve, I always put the keys near the valve, so I have to go there (and open the valve) before starting the engine. Many others probably know this trick, but everyone I've shown it to is impressed (as was I when someone showed it to me). If you respond, please do so in the thread, as I will get it, and others will benefit as well. In fact, I will post this email. Hope thats ok.
Thanks, Bill[
  #16 (permalink)
Old 08-17-2009
rikhall's Avatar
old guy :)
rikhall will become famous soon enough
I moved my raw water strainer about a foot lower and so far she has started fine both times we have been sailing. But - light winds and only 5 to 10 deg heel. We will see what 15 - 20 degs does.
I too have learned that boats are built to an optimum heel for optimum speed. Our Tanzer 28 sailed fastest at 15- 20, over 20 we lost a lot of speed and went "sideways" more
Have not figured out the IC24 yet.
Rik
Rik
Irwin Citation 34
  #17 (permalink)
Old 08-18-2009
L124C's Avatar
Rik
Rik
Just curious, what is the theory on moving the strainer down? I assume to get it below the water line on all points of sail? Seems to me that if it was full going out, it should stay full unless the intake is exposed to air.
  #18 (permalink)
Old 08-18-2009
rikhall's Avatar
old guy :)
Like I said - I am not sure the problem is fixed - just reporting what happened. If and when I really find out what caused the three "no water after sailing" happenings - I will let you all know. For now - it is try one thing at a time and see the results.
Rik
Irwin Citation 34
  #19 (permalink)
Old 08-18-2009
philsboat's Avatar
philsboat is on a distinguished road
Maybe you could install a tee in the line with a valve open to atmosphere so you could open it after sailing to burp out any trapped air.Had the same problem with an airconditioning pump on a Norseman 447.We just pulled the water line off to let the air out.A tee and a ball valve would be quicker.
Phil
  #20 (permalink)
Old 08-19-2009
L124C's Avatar
Phil
Where was the air coming from? It seems to me that if you have air in the system you've either got a leak (doesn't make sense in Rik's case), or you are draining water and taking on air in the intake while heeling. I'm betting that when Rik sails in some real wind the problem will occur again. I would shut the intake valve before heeling. If it doesn't occur...problem solved. If it does, I never claimed to be a mechanic It's hard to believe they would place an intake where it would be exposed to air in anything less than a knock down, but apparently they do. My intake is about a foot from my keel. If it sees daylight, I'm on my side!
Knutson K-35 CharlieCobra Orphan Brands 7 12-06-2009 05:03 PM
What a shame! berkshire1 General Discussion (sailing related) 38 08-18-2009 09:14 PM
