08-26-2009
I understand them sorta
The tachs for diesels that run off the alternator, count the pulses from the alternator. You have to set them for the number of poles the alternator has. Also, if you change pulley size, then they are off. I am not extremely familiar with this set up other than that. Can't you just return the one you bought, and then go to an auto supply and purchase a good tach for an auto. Four cylinder, four strokes are tachs that are easy to come by. They all read ignition pulses, and are easy to hook up. If you manage to hood up the tach you have, if the pulleys are not exactly the same ration as what it was intended for, it might read, but will not be anywhere close to accurate.
Dream like you will live forever. Live like you will die tomorrow. ( James Dean )
