Go Back   SailNet Community > General Interest Forums > Gear & Maintenance > Diesel Engine Forum
Diesel Engine Forum This is a new forum dedicated to diesel engines and their applicable accessories.
  #21 (permalink)
Old 09-17-2009
casioqv's Avatar
1974 Catalina 22
casioqv is on a distinguished road
My dad always keeps an "emergency prop loss kit" onboard. This consists of a heavy duty rubber work glove (not the disposable kind), a hose clamp, and a screwdriver. When we ran aground or hit a log and the prop and shaft are forcibly removed, we would just slide the glove over the shaft and tighten the clamp over it. We had to do this several times, and it worked excellent.
  #22 (permalink)
Old 09-17-2009
mitiempo's Avatar
Good idea. Also if you install a 2nd zinc to the shaft inside the boat close to the stuffing box it will prevent your shaft from leaving if the coupling becomes disconnected.
Brian
  #23 (permalink)
Old 10-20-2009
Waltthesalt is on a distinguished road
What if if the new shaft doesn't fit the cutlass bearing or if you damage it getting the shaft out.
What's your biggest bonehead move sailing? CharlieCobra Seamanship 421 09-26-2011 10:05 AM
Fixed vs. Free Wheeling Prop - Test Data Maine Sail Gear & Maintenance 18 01-26-2010 12:45 AM
Water, Water Everywhere Tania Aebi Cruising Articles 0 06-14-2004 08:00 PM
Basic Thoughts on Tides Jim Sexton Learning to Sail Articles 0 11-17-2003 07:00 PM
The Stuffing Box and Stern Tube Tom Wood Gear and Maintenance Articles 0 04-27-1999 08:00 PM
