replacing rear main oil seal universal 5424 - SailNet Community
Blogs
Go Back   SailNet Community > General Interest Forums > Gear & Maintenance > Diesel Engine Forum
Diesel Engine Forum This is a new forum dedicated to diesel engines and their applicable accessories.
Old 09-12-2009
argofred is on a distinguished road
Dear Sailnet: Anyone know whether the rear main oil seal on my Universal diesel is replaced by dropping the pan and crank or from the rear of the engine? After chugging along for 27 years without a drop in the pan it has stated to leak. Only a couple of teaspoons after 15 hours of use but I anticipate it may get worse in the future. Thanks! Fred
Old 09-12-2009
Maine Sail's Avatar
What makes you assume it's the rear main seal? Is it dripping from the weep hole in the bell housing? It could just be an oil pan leak.
The rear main on most all engines is removed off the output end of the crank with the flywheel, & sometimes bell housing, removed. If you do this be very careful to NOT scratch or mar the crank shaft in any way where it meets the rear mains bearing seal surface..
General Instructions:
Remove gear box:
Remove damper plate (you should use an impact driver and a mini butane torch for heat as many damper plate bolts are put in with red Loctite):
Remove flywheel; many times easier said than done due to moisture and the resulting rust. Use a brass or lead hammer if you need to whack it. Never use a metal harder or as hard as the flywheel.
Remove Flywheel; If the flywheel still won't slide off you can make a jig and use the damper plate as a puller. You'll want to replace the damper plate anyway while your in there.
Pulling Jig In Place:
Rear Main Seal; This one was only replaced because I was already "in there". Even at 3000 hours it was not leaking. The oil in and around that area was from a minor valve cover gasket leak.
New Seal:
While not a tough job in terms of difficulty level it can be tedious and time consuming..
______
-Maine Sail / CS-36T
Old 09-12-2009
Thanks Maine sail! Just what I needed to know with pictures. Will check pan vs weep hole as the source of the leak. It would be nice if the source is the pan as I just (last year) rebuilt the tranny with new damper plate and dripless shaft seal. Best, Fred
Old 09-13-2009
Pub911 is on a distinguished road
Thanks from ALL OF US Universal owners. I've been 1/2 way there or more, but this really helps if the need arises to press past the flywheel.
Cheers!
Old 09-13-2009
St Anna's Avatar
St Anna is on a distinguished road
Had the same thing on a Nanni 50Hp (marinised Kubota). Had to remove gear box and back part of the engine to replace a $15 rubber seal.
Exactly the same as MaineSail said. Quite stressful but more confident with engine stuff when finished.
Old 09-14-2009
recycle is on a distinguished road
How did you support the engine when removing the bell housing? Did you support it from the oil pan and was that strong enough?
Old 09-14-2009
St Anna's Avatar
I put an eye bolt through the cockpit floor to a stainless plate to spread the load, and used a chain pulley to maintain the engine at the same level.
The gear box came off with a crunch but no problems.
Oil Change experience - Lessons Learned kmeeks Gear & Maintenance 33 04-16-2010 09:55 AM
replacing rear main oil seal universal 5424 argofred Gear & Maintenance 0 09-12-2009 09:27 AM
Deisel Rear Main Seal pma_foyl Gear & Maintenance 1 06-22-2004 08:24 AM
Rear Seal Replacement tm3 Gear & Maintenance 2 01-07-2004 04:30 PM
Changing Engine Oil Tom Wood Gear and Maintenance Articles 0 10-02-2002 09:00 PM
SEO by vBSEO 3.6.0
(c) Sailnet 2000-2006
