09-24-2009
Diesel alignment
I'm repowering with a Beta 16, which comes with a "Drivesaver" coupling. The question is how to best align the new engine to the shaft. All guidance I've found requires the engine flange and shaft flange be aligned with the coupling removed. There seems to be two options for doing this:
Jack the shaft forward for the alignment then back aft to insert the coupling
or
Make up a steel disc the thickness of the coupling, attach it to one of the flanges, and do the alignment then remove it and install the coupling.
There mayt be other ways. I'd appreciate any advice on how to do this.
