Go Back   SailNet Community > General Interest Forums > Gear & Maintenance > Diesel Engine Forum
Diesel Engine Forum This is a new forum dedicated to diesel engines and their applicable accessories.
  #21 (permalink)
Old 10-15-2009
Omatako's Avatar
Omatako will become famous soon enough
Originally Posted by JimsCAL View Post
The fuel tank sensors have a varible resistor that is in the tank and exposed to the fuel. Water may short these out.
Yes I wondered about that but I'm not sure what the difference is between fuel and water. I sort of figured that they would act similarly.
Arthur C. Clarke
  #22 (permalink)
Old 10-15-2009
JimsCAL's Avatar
JimsCAL is on a distinguished road
I was surprised when I found out that the fuel tank sensor was constructed that way, but I guess the fuel doesn't short out the resistor like water would. Looks like the WEMA sensors (which work in water tanks) noted above have the same standard resistance charteristics and would work in a system with one display with standard fuel sensors from other manufacturers.
  #23 (permalink)
Old 11-28-2009
Mystiko is on a distinguished road
fuel sender
Want to add a fuel sender to a an aluminum diesel fuel tank. Is it ok just to drill into it with a hole saw when there is diesel fuel in the tank, taking care to vacuum up the cuttings as it is being cut with a shop vac so little falls into the tank? Is this safe or will the battery drill motor spark/s or heat from the friction of the drill be unsafe?
Thanks, and happy holidays.
  #24 (permalink)
Old 11-28-2009
mitiempo's Avatar
Hi
Don't put your emasil address in your post as you will get spam,
As far as the fuel sender, there will be bits you can't get with the vacuum and they could be a problem later. If the tank is aluminum and you go slowly there shouldn't be sparks. Hope this helps.
Brian
  #25 (permalink)
Old 11-28-2009
klem is on a distinguished road
With diesel fuel, this is not unsafe however it is extremely difficult to keep the chips out of the tank. If you can't drain the tank and then flush it several times afterwards, I would suggest one of two methods.
One method is to pressurize the tank and use a shop vac on the outside with the hope that all the chips will go out. This will work reasonably well as long as you keep the drill really straight and don't punch through one place before you punch through another.
The other method is to drill most of the way through, stop and clean, then put heavy grease on the bit which will hopefully make all of the chips stick to it.
You can also combine the methods. Fortunately I have always been able to drain the tank and then clean it afterwards but I have had to drill several exhaust manifolds with the above procedures.
Make sure you have a good fuel filter setup if you are doing this.
Diesel Fuel Essentials Tom Wood Gear and Maintenance Articles 0 03-22-2004 07:00 PM
Diesel Fuel Essentials Tom Wood Her Sailnet Articles 0 03-22-2004 07:00 PM
Gauge Problems Mark Matthews Gear and Maintenance Articles 0 09-24-2002 08:00 PM
Diesel Fuel Concerns SailNet Gear and Maintenance Articles 0 07-08-2002 08:00 PM
Cleaning Fuel Tanks Sue & Larry Gear and Maintenance Articles 0 03-21-2002 07:00 PM
