universal/kubota Alternators - SailNet Community
Blogs
Go Back   SailNet Community > General Interest Forums > Gear & Maintenance > Diesel Engine Forum
Diesel Engine Forum This is a new forum dedicated to diesel engines and their applicable accessories.
Old 11-05-2009
deniseO30's Avatar
Lies about her age
I know I need new batteries, 2 trojan golf cart 6 volts, and 2, 12 volt. I'll be taking the out and getting them checked first.
My alternator works but I can't help but think it's on borrowed time. Should I take to to a local guy that I spoke with? Or keep it as a spare and get another? I like the idea of a spare anything on the boat on the other hand I funds are tight.
the big question is which "off the shelf" units will go on my Universal 5416?
thanks all.
Old 11-05-2009
I had my existing alternator rebuilt and upgraded from 30 amps to 70 amps for about the same price as a replacement - the advantage being that all the mounting brackets and connectors still fit. It ended up being about an inch longer, but there was no interference in that direction.
1984 Fast/Nicholson 345
Old 11-05-2009
JimsCAL's Avatar
JimsCAL is on a distinguished road
The standard alternator on that engine is rated at 55 amps and is internally regulated. Fine for topping off a group 24 or 27 battery or two, but not the best for charging a house bank of 6V golf cart batteries. Consider a higher output unit with a multi-stage external regulator.
Old 11-05-2009
Maine Sail's Avatar
Alternators.
Denise,
Today is your lucky day. I have photographs of the Universal part #'s stuck onto the actual Leece-Neville alternators taken on the counter of my local Universal Distributor.
You can buy the 8MR2070TA from ASE Supply for $201.49:
8MR2070TA (LINK)
You could buy this alt from Universal/Westerbeke for $648.00
There is also the 72 amp #300746:
ASE could order this one for you but they don't stock it.
Universal sells this alt for $642.00 (LINK)..
Personally, I would re-build what you have and use it. For what you have, and how you use it, there is no need to get fancy.
______
-Maine Sail / CS-36T
Old 11-05-2009
deniseO30's Avatar
Lies about her age
Kewl! MS! thanks! it is my lucky day! I think the PO said that it had a 70 amp but I dont' know. It does have a "box" on the back. it's all been painted white from when the engine was "replaced" No way to know but most people don't remove engines to just paint them .. or do they? LOL
Thanks!
High capacity alternators wwilson Gear & Maintenance 11 03-29-2005 02:25 AM
High Output Alternators Stormer_2003 Gear & Maintenance 3 10-13-2004 01:16 PM
SEO by vBSEO 3.6.0
(c) Sailnet 2000-2006
