12-09-2009
Finally found the needle!
A long time ago, you could get negative rep points  . Maybe these rep points need to be cleaned  ?
If it were my boat though, I'd start looking at the fuel system. Some boats have a fuel strainer in the tank, a primary, and a secondary filter (which makes 3 filters!). I'd check all three.
The vent tube is a great idea. You can test that theory by removing the fuel cover when the engine begins to bog down. If removing the cover corrects the problem, the problem is the vent. If not, I would bet on one of the filters.
