Go Back   SailNet Community > General Interest Forums > Gear & Maintenance > Diesel Engine Forum
Diesel Engine Forum This is a new forum dedicated to diesel engines and their applicable accessories.
  #1
Old 12-06-2009
bossk's Avatar
bossk is on a distinguished road
Question Westerbeke Oil Change
I've done a search but I can't seem to find an answer. Simple question though, which way does the oil filter thread off? Is it a reverse thread? I went to do a change this weekend, got all the oil pumped out, but the filter wouldn't budge. I didn't want to force one way or the other until I was sure which way I should force. On top of the usual ZERO room to do anything
Anyone with a Westerbeke and some experience know what what I should be twisting to get the beast off. I've got a 85' 10-Two, but I'm hoping Westerbeke threads standard across the board.........
Thanks guys!
-Jon
  #2
Old 12-06-2009
It's HIGHLY unlikely to be a reverse thread... sounds like it's been quite a while since it's been changed.
Sometimes when all else fails you can punch a screwdriver through the filter body and break it free that way.. but you do need some space. How about one of those "cupped' socket wrench fittings that fit over the end of the filter itself?
  #3
Old 12-06-2009
bossk's Avatar
Yeah I'm pretty sure it's standard counter clockwise to remove but I didn't want to force it till someone else offered an opinion . I've got a wrench that goes on the end fits the top of the new filter like a glove but loose and pops off on the old one. I need to get one of the kind that slides over and ratchets tight. I'm very low on room but and probably get a screw driver through in a pinch. The oil was done about a year ago. Figured it was time to get changed for the winter season!
I will get the new wrench and give it a try tomorrow evening. Wish me luck!
-Jon
  #4
Old 12-08-2009
Fareast is on a distinguished road
I have a Westerbeke 64A, it turns counter clockwise to remove. I do have a remote on mine, but it is still counter clockwise...
Mike & Paula
S/V Tivoli
  #5
Old 12-21-2009
marcberoz is on a distinguished road
My Westerbeke 21 oil filter turns counterclockwise to remove.
  #6
Old 12-21-2009
Tempest is on a distinguished road
If you have the proper replacement filter...look at the threads on the filter....
Tempest
Sabre 34
Morgan, NJ
  #7
Old 12-22-2009
JVallely is on a distinguished road
Every oil filter made since right and left were invented has threads that tighten to the right.
Left-handed threads are for mounting wheels, pulleys, tool heads etc that turn clockwise, so the threads don't work loose. Turning your filter counterclockwise will loosen it.
The screwdriver trick works sometimes, but if you end up tearing up the paper-thin aluminum case with it, you'll have nothing left to grip. So be careful. Your idea of using the metal strap type that takes a ratchet drive and tightens as you turn it is probably your best bet. Now is your excuse to splurge on a long-handled ratchet, if you have the room to swing it. Obviously a long drive extension may let you move the handle up or down to where you might have more room.
Just don't use it to tighten the new one on, as you are probably aware.
John V.
  #8
Old 12-31-2009
bossk's Avatar
Yeah it wasn't budging with anything, so a screw driver it was! There isn't much room to work either, just enough to get my arm down the side and the filter is tucked in close to the engine as well. So two seperate punches and she finally threaded off. And up, I only hand tightened the new one Done many many a oil filter change on a car back in high school auto class. I just wanted to be sure there wasn't something odd at play here seeing as it was on so tight.
All is now happy in the land of Westerbeke Oil changes
Thanks again folks!
-Jon
  #9
Old 12-31-2009
eherlihy's Avatar
Will work to sail. :-)
eherlihy will become famous soon enough
Thanks for the update. I'm not a fan of the screwdriver method, as it frequently tears the can, and then you have even less area to work with. (When this happened to me, I used a chisel to get a bite on the mounting plate, and swore that I'd never try the screwdriver trick again.)
Now that you've mounted a filter, take a look at the oil filter review page here - Read it and you'll understand why every time I see a Fram filter on a boat I have to bite my tongue.
USCG Licensed OUPV Captain, ASA 101/103/104/105 Certified - Also certified in Recreational Marine Electrical Systems
  #10
Old 12-31-2009
NICHOLSON58's Avatar
Mark on Camper 58
NICHOLSON58 is on a distinguished road
"LEFTY - LOOSEY RIGHTY - TIGHTY" Hey, it helps my wife remember.
You may post attachments
You may edit your posts
Oil Change experience - Lessons Learned kmeeks Gear & Maintenance 33 04-16-2010 08:55 AM
Oil change for 3YM30 diesel engine pkats Beneteau 5 10-29-2009 08:55 PM
W60 - No oil pressure after oil change??? pma_foyl Gear & Maintenance 9 12-01-2004 09:45 AM
Oil Change Pump?? ikent Gear & Maintenance 3 07-22-2003 06:26 AM
Changing Engine Oil Tom Wood Gear and Maintenance Articles 0 10-02-2002 08:00 PM
SEO by vBSEO 3.6.1
