Go Back   SailNet Community > General Interest Forums > Gear & Maintenance > Diesel Engine Forum
Diesel Engine Forum This is a new forum dedicated to diesel engines and their applicable accessories.
  #1
Old 02-01-2010
krob2002 is on a distinguished road
Our prop falls out of the ballancer-Westerbeke
Well, we finally got our Westerbeke 4 started and after running for about 5 minutes the prop shaft shakes out of the balancer. We would love a suggestion on how to fix this. It's just bizzare and there is no holes to bolt it onto the balancer. What are we missing?
4 weeks a counting until we sail out from Charleston, SC.
Katie
Sorry about the typo in the header.
  #2
Old 02-01-2010
Maine Sail's Avatar
Balancer?
Do you mean the shaft coupling that bolts to the transmission and accepts the shaft?
A photo may help. If it is sliding out of a coupling you'll likely need a new one as the tolerances on the old one may be toast.
______
-Maine Sail / CS-36T
  #3
Old 02-01-2010
The shaft goes into the balancer and the balancer bolts to the transmission. The balancer has a keyway which matches the slot on the propshaft. The two retaining bolts screw into the balancer to grip the propshaft. There is nothing for them to grab but the smooth hard metal of the shaft. It vibrates out slowly in forward gear and comes out very quickly when in reverse.
We maybe able to get a picture tomorrow when we get the memory card for our camera.
  #4
Old 02-01-2010
motion300 is on a distinguished road
That is a coupler you need a new one
  #5
Old 02-01-2010
Thanks for the quick response. You guys are the greatest.
You may post attachments
You may edit your posts
3-blade fixed prop recommendations? KeelHaulin Gear & Maintenance 28 09-29-2012 08:02 PM
1 inch prop on 25mm prop shaft? lawsonmitchell Gear & Maintenance 2 11-28-2009 02:19 PM
Max prop on a saildrive levenezia Gear & Maintenance 16 09-20-2006 12:07 AM
Choosing the Right Propeller Sue & Larry Gear and Maintenance Articles 0 02-04-2003 07:00 PM
Choosing a Prop Sue & Larry Gear and Maintenance Articles 0 12-24-2001 07:00 PM
SEO by vBSEO 3.6.1
