Go Back   SailNet Community > General Interest Forums > Gear & Maintenance > Diesel Engine Forum
Diesel Engine Forum This is a new forum dedicated to diesel engines and their applicable accessories.
  #1
Old 03-01-2010
cutterorient is on a distinguished road
Exhaust sealant
As part of another job I disconnected the exhaust hoses from the muffler. Pulling them apart I noticed there was a reddish colored sealant used between the male fitting on the box and the hose. It was silicone like in texture.
Does anyone know what this stuff is called as I will need more for reassembly.
Maine Sail, since I know you will read this, I noticed on your oil change video that the oil drain plug cap needs to be painted again I also wanted to say your posts and photos made my life tons easier when I pulled the trans, heated the bolts on the damper plate, etc. Great, generous info. Thanks.
  #2
Old 03-01-2010
Chances are good that it was an RTV silicone sealant like those sold by Permatex.
  #3
Old 03-01-2010
pedcab's Avatar
pedcab is on a distinguished road
I'd recommend this:
GE Silicone II Gasket & Seal Is Waterproof and Airtight, and Resists UV, Oil, and Grease
Sometimes it pays to pay extra for a good brand
Regards!
Pedro
Portugal
  #4
Old 03-01-2010
pedcab's Avatar
Before people come on beating me saying that this product I've suggested is not heat resistant I recomend clicking on the link and reading throught the spec summary before posting...
I'm not in any way affiliated to GE, but I should recommend what is indeed good and proven...
Furthermore nothing too fancy in terms of heat resistance should be required for a boat's exhaust system anywhere downstream of the manifold flanges because boat's exhausts are "cool" systems and run wet for most of the time...
That's why mufflers, hoses and the works are mostly made out of fairly low heat resistant materials...
Pedro
Portugal
  #5
Old 03-07-2010
Mechsmith
Mechsmith is on a distinguished road
I have used the Permatex red RTV even on a dry exaust and it has been satisfactory.
Have everything clean, lightly sanded and a pretty good fit also.
Seafarer 29 KCB
  #6
Old 03-07-2010
tager's Avatar
tager is on a distinguished road
Since when is permatex a cheap brand?
  #7
Old 03-07-2010
Going cheap often means doing the job twice... if you pay a little extra it is often worth it in time and aggravation saved.
  #8
Old 03-08-2010
imagine2frolic's Avatar
imagine2frolic is on a distinguished road
I have been in the exhaust business for 33 years. I use Permatex Copper sealant in connections that are questionable. I used it on my new mufflers 4 years ago on Imagine, and not a problem. There's more than one way to skin a cat..........i2f
20 MPH ain't fast unless, you do it in a 1000sq 3/2 house on 10foot waves
BORROWED, No single one of us is as smart as all of us!
  #9
Old 03-22-2010
Red
redhead78 is on a distinguished road
Hey, guy,s I just did some new exhaust work this weekend, I used only clamps, should I use sealant. I brought exhaust out of transome, can I use something like teflon thread paste????? Should All connections use this??? Red
Red, 77 Jeanneau Gin Fizz 38
  #10
Old 03-22-2010
It most likely is not needed if everything is clean. I use it for insurance to keep from having to go back in a small hole.......i2f
You may post attachments
You may edit your posts
Hatch lens ccracked in half - best place for replacement? Bene505 Gear & Maintenance 14 05-06-2010 10:43 PM
Atomic 4 Exhaust fbycericson Ericson 5 02-07-2008 02:05 PM
Choosing and Using Sealants Don Casey Her Sailnet Articles 0 01-22-2003 07:00 PM
Diesel Exhaust Systems Sue & Larry Gear and Maintenance Articles 0 11-07-2001 07:00 PM
Cat30 Exhaust riser blew up - Engine won''t start E_N_Z_O Gear & Maintenance 2 07-31-2001 06:55 PM
SEO by vBSEO 3.6.1
