08-10-2010
Difference?
Originally Posted by cardiacpaul
thats a "Racor" filter.
while not specifically a water separator, it will do the job. Yes, drain the water out of the bowl... then stop, no need to drain the whole bowl.
You can certainly install a separate water separator if you wish, and leave this as your fuel filter, but... if it ain't broke...
The filter is designed to remove water at a 99% efficiency rate. What the saturation point or maximum amount of water it can handle before it needs to be replaced, I do not know. Therefore, per the OP's query, his R11T will separate out the water from his fuel. I don't understand what you mean above re: not specifically a water separator. What is the difference between a water "separator" and a an element that filters/separates out water from fuel?
DrB
If you liked my advice/response, give me some rep points. If you didn't......well what do you expect, it was free.
