10-04-2011
Break, curse, fix, repeat
Since I did not recall the original post saying anything about leaking, and only about gunk, I agree with MedSailor that there are far cheaper and easier options to replacing the tank. I replaced the tank on my old Ericson 28 and so know of what I speak.
Another idea in addition to the cleaning ports mentioned above, is to purchase some B99 biodiesel and run that through. Make sure you have a good Racor primary filter (which you should anyway) and prepare to change it out a few times in the beginning. Also, make sure your diesel runs on the hot side, if it is fresh water cooled. A common problem is to have a thermostat that has her running at 160 or so, when the combustion temperature of diesel, especially biodiesel is higher and benefits from higher operating temperatures. I replaced the 160 stock thermostat on my Gulf with a 185 and greatly reduced the soot on the transom and did wonders for my engine.
Anyway, I ran biodiesel a while, replace a few filters, did a self polishing of opening my tank and agitating it while running the fuel pump through the filter and back to the tank, and now my tank and fuel system is so damn clean I replace my filters every year just for the formality of doing it. They are pristine after a long hard season.
Aeolus
Gulf 32
Bainbridge Island, WA
