Go Back   SailNet Community > General Interest Forums > Gear & Maintenance > Diesel Engine Forum
Diesel Engine Forum This is a new forum dedicated to diesel engines and their applicable accessories.
  #1
Old 09-12-2010
stuartsw's Avatar
new member
stuartsw is on a distinguished road
Shaft Log Drip: What's acceptable?
Any ideas on what an acceptable drip rate is on a shaft log? It's been dripping since we bought the boat new, and I had it adjusted at the 50hr tune-up, but it now leaks (after working the prop shaft) at a rate less than 1s, and (after several days' rest) at a rate of 22s.
At what point does a repacking become necessary?
I'm working with a marine gear on a Yanmar 30
  #2
Old 09-12-2010
mitiempo's Avatar
It should drip 3 to 5 times a minute when the shaft is turning. The stuffing box should not feel hot to the touch when running. It should not drip at all when the engine is not running.
Brian
You may post attachments
You may edit your posts
infernal drip QuickMick Gear & Maintenance 6 09-09-2010 03:00 PM
Leaking oil drip pan - liner? Mary51 Gear & Maintenance 13 08-07-2008 10:18 AM
Acceptable installation of rigging terminals royt Gear & Maintenance 2 02-06-2008 09:11 AM
Drip Shield JLBJR Gear & Maintenance 5 12-15-2007 04:17 PM
acceptable or unaceptable digny?? sailboatlover General Discussion (sailing related) 14 09-14-2007 06:31 PM
SEO by vBSEO 3.6.1
