Go Back   SailNet Community > General Interest Forums > Gear & Maintenance > Diesel Engine Forum
Diesel Engine Forum This is a new forum dedicated to diesel engines and their applicable accessories.
  #11 (permalink)
Old 01-03-2011
Thanks for the follow-up! Well done.
1984 Fast/Nicholson 345
  #12 (permalink)
Old 01-03-2011
Omatako's Avatar
Omatako will become famous soon enough
You should have used a bigger bar :-)
Arthur C. Clarke
  #13 (permalink)
Old 01-03-2011
S34 S34 is offline
S34 is on a distinguished road
I had a 24" crescent, but it kept jumping off the nut.
  #14 (permalink)
Old 01-09-2011
Northeaster is on a distinguished road
Smart. Well done. Nice to see examples like this, in case one needs something similar in the future.
  #15 (permalink)
Old 01-12-2012
pierrrre is on a distinguished road
Thanks S34 for your explaination. I am in the process to rebore my 3GM30 and last evening I screwed around with this disc for at least an hour before giving up. I removed the 6 bolts retaining the disc but it would just not come off. I stopped because I was afraid to damage something. Now that I know that it will come off by pulling on it, I will give it another try tonight. I was reading your first post like if I wrote it.
Thanks again
  #16 (permalink)
Old 01-12-2012
S34 S34 is offline
Just be gentle with the female spline. The splines can be deformed easily, as I found out before I used the coach bolt method.(levering with a bar down the spline) A small triangular rat-tail file soon set the grooves right.
I had to reduce the diameter of the coach bolt head to just fit inside the female spline, as nothing "off -my-shelf", with the right length of thread, was suitable.
The old adage, "there is an easy way to do everthing is so true."
All the best for 2012!
  #17 (permalink)
Old 01-12-2012
Hi
That's it. I removed it using your method. The little bugger was stuck in there solid. I did not bother using a steel bar like you. I just used a piece of 2x3. I figured it you'll be easier to drill the hole.
The only negative is that three out of five bolts broke in the crankshaft. I drilled and removed one already. Two more to go.
Thanks for your help.
Yanmar 3gm30 transmission olepedersen@yahoo.com Gear & Maintenance 7 10-06-2008 11:10 AM
IP31 yanmar 3gm30 badsanta Island Packet 10 06-07-2008 12:34 AM
Yanmar 3GM30 salt water in intake manifold Peregrina Gear & Maintenance 18 04-06-2008 07:10 PM
Yanmar 3GM30 Salt water in intake manifold Peregrina SailNet Website Technical Support 0 03-31-2008 02:51 PM
Replacement prop on a Yanmar 3GM30 dave6330 Gear & Maintenance 0 10-22-2007 03:10 PM
