Go Back   SailNet Community > General Interest Forums > Gear & Maintenance > Diesel Engine Forum
Diesel Engine Forum This is a new forum dedicated to diesel engines and their applicable accessories.
  #1
Old 11-01-2010
gbm4th is on a distinguished road
New Diesel Engine, Low Load Charging
I was wondering if the newer diesel engines (Beta Marine 25) still preferred to work under a full load as opposed to cruising along under partial load. I have read about carbon build up and condensation if the engine does not achieve adequate operating temperatures. I would prefer to avoid that with my new engine if possible.
Thanks,
george
  #2
Old 11-01-2010
jrd22's Avatar
Courtney the Dancer
All diesels should be run under some load, but generally speaking they will come up to operating temp even at a fairly low throttle setting when in gear. I always run a new engine pretty hard at different rpms for the first 50+ hours to prevent glazing of the cylinders but after that I'm pretty easy on them (I don't adhere to the factory recommendations that you always have to run at 80% of full load).
John
SV Laurie Anne
1988 Brewer 40 Pilothouse
  #3
Old 11-02-2010
JimsCAL's Avatar
JimsCAL is on a distinguished road
Not a lot of change in the basic design of diesels in the last 30 years. The Beta is a Kubota engine, just like the Universal diesels of the 1970s. Still not a good idea to run the engine at idle for long periods, but as long as it gets a run at load regularly, you will be fine.
  #4
Old 11-03-2010
Stu Jackson's Avatar
Stu Jackson is on a distinguished road
Excuse me, but you have a brand new engine. What does you MANUAL say to do? I know, it's a guy thing, right?
Stu Jackson, C34, 1986, M25 engine, Rocna 10 (22#)
  #5
Old 11-03-2010
Thanks for the replies.
I have ordered the engine but have not received it yet and it won't be installed till spring 2011.
George
  #6
Old 11-03-2010
Maine Sail's Avatar
George
Beta has their own forums, HERE. Why don't you ask them and see what they say specifically around warranty and low load engine idling.
______
-Maine Sail / CS-36T
  #7
Old 11-04-2010
1. I have ordered the engine but have not received it yet and it won't be installed till spring 2011.
2. I have read about carbon build up and condensation if the engine does not achieve adequate operating temperatures.
1. Can you not ask the dealer for a manual, now?
2. That's usually true for all diesels. Operationally, just run it til it reaches operating temperature, only a few minutes at cruising load will do it every time. If you're planning to run it at only 1500 rpms for charging your house bank, then you need to start thinking about your overall electrical systems, bank capacity and the like, which is a whole 'nother topic.
You may post attachments
You may edit your posts
Charging the batteries by running the diesel... SoulVoyage Diesel Engine Forum 16 11-14-2010 11:08 AM
Charging battery from old outboard engine 99miles Gear & Maintenance 8 06-01-2010 03:28 PM
Engine will not crank and required charging time ekenna Electrical Systems 12 05-14-2010 07:50 PM
High Output Alt and Engine Load KindOfBlue Gear & Maintenance 2 03-28-2009 11:13 AM
Diesel stalls under alternator load Pub911 Gear & Maintenance 7 11-27-2007 06:22 PM
SEO by vBSEO 3.6.1
