Go Back   SailNet Community > General Interest Forums > Gear & Maintenance > Diesel Engine Forum
Diesel Engine Forum This is a new forum dedicated to diesel engines and their applicable accessories.
Old 12-19-2010
birdlives is on a distinguished road
Volvo Penta opinions?
Hello all,
Does anyone have experience with a Volvo MD2040C? I would be interested in good and bad points, opinions, facts, things to watch out for and good stuff.'
Thanks
Old 12-19-2010
Hartley18's Avatar
Termite Fodder
Hartley18 will become famous soon enough Hartley18 will become famous soon enough
I have an MD2040A which is the same as the 'C' but without the upgraded electrics and more shapely heat exchanger.
They're a nice engine - once you get over the fact that they're not a Yanmar or a Bukh and resign yourself to the knowledge that parts are going to cost you an arm plus a leg or two!!
Down-sides:
- Uses glow-plugs, so it takes 10-15secs to start the engine.
- I have the 'standard' panel with the on/off button - and keep forgetting to turn the ignition off.
Up-sides:
- Very quiet - for a diesel engine. Acoustic insulation is optional.
- Plenty of grunt and low-down torque (with my 6-ton boat I can still happily tow someone else without any noticeable complaint from the engine!)
There isn't much to look out for other than the usual smoky exhaust (it shouldn't) and to check the impeller (right on the front and very easy to get at). Make sure there are no diesel leaks around the injection pump or injectors that might indicate something is wearing out and needs replacement.
Am I happy with this one? Yep. If I was re-engining and had a choice, would I get another?? Probably not.
Hope this helps.
Crew member on the Womboat for:
2011 Heaven Can Wait 24Hr - Race against Cancer.
Old 12-19-2010
Thanks so much, a very helpful reply. I am used to a YSM8 with no glowplugs and starting it in cold weather was always tough. Had to become a contortionist to hold the decompression lever and push the starter at the same time.
Glow plugs don't sound so bad.
Old 12-19-2010
Hartley18's Avatar
Termite Fodder
I understand. There is absolutely no way you can start an MD2040 by hand, so you're kind of reliant on the electrics - one of the things they tweaked in the 'C', IIRC.
Compared to what you've been used to, this thing will be a breeze!!
Old 12-25-2010
negrini is on a distinguished road
Send a message via AIM to negrini Send a message via Yahoo to negrini Send a message via Skype™ to negrini
I had a MD2040C on a 40 feet some years ago. I had replaced a very old MD13, and was very happy with engine performance. The boat belongs now to a friend wich have 3900 hours on it and still runs like new. Hartley is correct about parts price, but you'll find a great worldwide support, and rarely the parts supplier doesn't have what you need at store. Regarding the improved heat exchanger, I had some problems. During the engine replacement, I mistakingly stepped over the water tap, right above the exchanger reservatory, to make in and out of the cabin. It created a very tinny crack on the tap neck that allowed a very small amount of water leaking from it. Strangely, as the temperature raised (not to a point to sound the alarm), the rubber that separate the salt water from the fresh water on the heat exchanger, became loosy and allowed some salt water mix. Overtime, the process continued as I didn't note the small leak under the cap, making the internal coolant completely salt, and the never got any alarm, since temperature became under control all the time. After some weeks, I noticed the leak as it left a clear trace of dry salt. I did try many alternatives to fix the cap, and after a year or so, the only remedy was the complete replacement of the heat exchange ... a very expensive repair. I enjoyed the engine smoothnes some more years, but if I need to choose one, I'll stick to my recent Yanmars !
Nave Rara
Beneteau Oceanis 43
old volvo penta single... jobi Diesel Engine Forum 31 07-13-2010 08:03 PM
Volvo Penta 39 jernhenrik Gear & Maintenance 0 10-18-2009 12:00 PM
Volvo Penta MD2B OleCheers Gear & Maintenance 3 02-20-2009 09:04 PM
Volvo Penta engine rondezvous Gear & Maintenance 1 09-24-2006 12:24 PM
Volvo/Penta MD7A paulinet. Gear & Maintenance 1 11-26-2001 01:50 PM
