09-26-2011
Originally Posted by dreuge
A bit of advise to those changing engine zincs for the first time (or those having a really hard time getting the zinc mount bolt off). Always USE a good metallic anti-seize when you screw back the zinc mount bolt. If not, the mount treads will likely corrode, gall-weld together in short time. Many DIY'ers learn this lesson the hard way. For most bolts, a good grease is fine, but for zincs the electrical conductivity between the plug and the engine block is crucial.
Most anti-seize contain graphite with metal of some form (usually copper) which maintains the electrical conductivity. For marine environments, use an anti-seize with nickel. You will pay about $3 more per 8oz can, but then again, an 8oz can will last the average owner a life-time. I prefer marine Never Seez but Peratex nickel anti-seize is just as good. I use it every where...
I did use a carbon based anti sieze on my zinc plugs (it is a marine type and suggested for use on spark plugs, so should not effect the conductivity needed).
I have read not to use the carbon base anti sieze on stainless steel or bronze, would the Never Seez or Peratex nickel be ok for my stainless standing rigging fittings (turnbuckels)?
I was planning to use some
