Go Back   SailNet Community > General Interest Forums > Gear & Maintenance > Diesel Engine Forum
Diesel Engine Forum This is a new forum dedicated to diesel engines and their applicable accessories.
  #1
Old 04-21-2011
Dufour 27 Newb
jaybeegee is on a distinguished road
beta marine BD722 newbie question re-coolant/zinc anode!
Hi All! I have been a sailing boat owner for the past 5months and still a long way to go but thanks to the tips in this forum making good progress! So I have a question regarding the zinc anode which I was told by a service engineer (supposedly an expert) who I brought to service my engine (model Beta Marine 20HP BD722) that was not used for a couple of years that this model does not use a zinc anode!!! Seems he was pretty wrong with that info and since ordered from the UK for an anode replacement.
My concern is that there must be a lot of corrosive residue sitting inside the cooling system as a result of not having the anode. In fact already have some problems as I am trying to drain off the coolant with little success! If I remove the coolant pressure valve (see pic) with the lid off, there must be some blockage as nothing comes out! Inserting some wire does not help.
I was told I could leave some chemical overnight to clean the inside - any ideas what this is and if it is recommended?
If the blockage remains, how would I clean?
thanks for your help.
Jay
  #2
Old 04-21-2011
Dufour 27 Newb
Noob update 2!
Just realised that the coolant blockage is not related to the zinc anode as that is part of the sea water circuit!
  #3
Old 04-21-2011
JimsCAL's Avatar
JimsCAL is on a distinguished road
Sounds like the fresh water side needs to be flushed. A product available for flushing an automobile cooling system should work fine.
And yes, the zinc protects the salt water side.
You may post attachments
You may edit your posts
Removing Zinc Anode Plugs from Engine casey1999 Diesel Engine Forum 24 09-26-2011 06:15 PM
Extra Zinc Anode bartvdv Gear & Maintenance 4 08-26-2010 11:53 AM
zinc anode locations granche1 Pacific Seacraft 4 02-21-2010 12:21 PM
Re-powering a Pearson 323 with Beta Marine jvsail Pearson 2 04-13-2009 11:23 AM
Zinc Anode Kestrel303 Gear & Maintenance 23 03-23-2009 06:41 AM
SEO by vBSEO 3.6.1
