04-26-2011
cruising all I can
Welcome to the world of hurth transmissions. I also had a hurth 100 and I can assure you that the slipping is indicative of a failing trans. When it will totaly fail cannot be known.
Oddly, according to the hurth websight out of SW Florida as per their specifications 300 hours behind a 25-30 hp. engine is all they idicate is to be expcted with what they refer to as recratioal use ! rather hard to believe !
After I "re-built" the H-100 the first time it lasted the exected time (about 3-400 hrs behind a 30hp) and began to slip once again.
Rather than re-pair/build a second time I found a H-125 which is only about 1/2" longer than the H100 but is rated for (if I remember) a 50hp engine application. I purchased the H125 used and ran it many hours thus far (I would need to check the engine log ) and it seems to be hoding up.
I'm not a fan of Foley engines as I've read on SN that they utilize inferior aftermrket parts, and charge Waaaaayyy too much.
If you do decide to re-pair your tranny it is relatively easy w/ the failed part usually being the bronze/brass thrust washer (I think it cost me $40) there are 2 ,one for forward-one reverse. you'll probably only need the forward one. This is a designed wear item. when you dis-assemble the unit you can measure the wear of each part and you will find the washer worn beyond spec. and probably little wear on the clutch discs. the spacing upon assembly is the critical measurement. too loose -slippage, to tight - excessive heat and wear leading to earlier failure.
So get a god set of feeler guages,micrometers,and a 2-5 ton press , study the trans. manual and mentaly prepare yourself for the dis-assembly and re-assembly . It's not that daunting a task,really !
Or find a H125 or 150 and shoe-horn it in place of the old H100 .
I did mine while at anchor both times. After changing to the H125 I had to also change the propellor as the ratio of the tranny was different. the saving grace was I found good used R19-11 prop. for $300 and the old one was all done anyway (red,sign of iminent faiure).
Changing the ratio will most likely require a different prop. Unless the prop you currently have is sized improperly which could lead to early tranny failing due to excessive heat, the bain of the hurth tranny.
A heat exchanger is available for these trannies and is a good value due to the fact that the engine comparments on sailboats are often poorly ventilated creating a bad envroment for heat challenged equipment. you indicated you were in the tropics. Also frequent oil changes (only uses about 1/2 quart) and switching to synthetic oil will help disapate the heat better.
good luck.
