Go Back   SailNet Community > General Interest Forums > Gear & Maintenance > Diesel Engine Forum
Diesel Engine Forum This is a new forum dedicated to diesel engines and their applicable accessories.
  #11 (permalink)
Old 05-07-2011
Omatako's Avatar
Omatako will become famous soon enough
The exhaust elbow on my boat is made of glass fibre and it works just fine. Surely if a glass fibre elbow survives a Yanmar 4 cylinder engine, an ali one will too?
Where did the data come from that determines that ali is not acceptable for a wet exhaust elbow? It would surprise me.
Arthur C. Clarke
  #12 (permalink)
Old 05-09-2011
MARC2012's Avatar
MARC2012 is on a distinguished road
Al and Fe have problems due to corrosion.marc
  #13 (permalink)
Old 05-11-2011
SeaLife Sailing
SeaLifeSailing is on a distinguished road
Mixing elbow
I had an exhaust mixing elbow blow up on my Yanmar 3GMD (raw water cooled). I solved it by having a custom elbow manufactured from 316 Stainless, which is the metal used in corrosive oil and gas processing applications. The original part is made of thin, mild steel and has a mission life of between 5-7 years in salt water. Here's a link to my post on the subject, with pics... Good luck with your replacement...
http://www.sailnet.com/forums/diesel...ing-elbow.html
Originally Posted by SantaAna12 View Post
My Westerbeke 30 exhaust elbow bit the dust. I was surprised and quite happy to order a seemingly exact replacement.....turns out it was made out of aluminum. As I researched it, this is not an acceptable material for diesel wet exhausts. However, the seller says he has "sold hundreds of these" and that it is no problem. Did I read the ABYC pfd incorrectly?
http://www.abycinc.org/committees/P-01.pdf
Anyone with experience in this? Anyone know where I can get one like this in a material from table 1?:
MMD MMD33067 90 Degree Exhaust Elbow, 1-1/2\" - Torresen Marine - The Sailboat Specialist
Gary
P.S. The dealer is NOT Torrensen, and I would prefer to leave them nameless as I have no prior experience with them. I used the Torrensen link because it has a color pic.
Jeremy Gow
SeaLife Sailing (Sailing School Operator)
Vancouver, BC
Lancer 36
s/v 'Ma Provence'
  #14 (permalink)
Old 06-23-2011
Bateau25 is on a distinguished road
I have a 5411 and replaced the exhaust elbow which was made up of 1-1/4" black iron schedule 40 elbows(3), nipples(4) and one street elbow. $29 in all at Home Depot! Had a 3/8 x 3 " black iron nipple welded at an angle two inches from the lowest point of the "dry stack" portion, wrapped it up with fiberglass exhaust wrap ($24 from marine supply) and it was good to go! A bit heavy though, but it should last 4 to 5 years like the first one!
Bateau25
  #15 (permalink)
Old 08-06-2011
wescarroll is on a distinguished road
When mine went I replaced it with a cast iron elbo and a "t" fitting 8 years ago with no problems. I have been wondering for years why do we use that proprietary (read expensive) elbow instead of using a t fitting and street elbow?
Where do I find an exhaust elbow leeisagenius General Discussion (sailing related) 2 07-24-2010 03:41 PM
2GM20F Exhaust Elbow thisisus Diesel Engine Forum 8 07-19-2009 06:34 PM
Atomic 4 Exhaust Elbow steich Gear & Maintenance 13 12-26-2008 06:57 PM
Universal 5411 exhaust elbow cooltec Gear & Maintenance 2 06-25-2007 06:20 PM
Exhaust mixing elbow I-33 Gear & Maintenance 2 12-02-2006 03:24 PM
