Hello all,
I have been lurking around here for some time, it is amazing all the knowledge I was able to gain by reading all the postings and searching for topics. From everything I learned here I felt comfortable in moving up from my O'day 26 to an H34. Also thanks to all the posters about the H34 compression post issue, I made sure to check that out first thing and I don't seem to have that issue, all of your postings were big help.
Anyway, I purchased the new to me 1985 Hunter 34 back in October, it was on the hard for so it has been a long winter while I wait to take it out. It has a Yanmar 3GMF with 850ish hours and I have a few questions, the whole engine thing is new to me and I want to learn as much as possible. It started up within 5 to 10 seconds when I had it surveyed the surveyor said, most major issues with a diesel you will know from how it starts up, runs and idles. It started up without complaints and ran and idled well, so the surveyor seemed comfortable in saying the engine was in good condition. I was able to run it with the cooling line attached to a hose several times in the fall, and I had no problems. So last weekend we took it out for the first time, very exciting, and we ran into some weather on the way back and had to motor for about 2 hrs. I made sure to not exceed 3000 RPM as I did not want to push the engine too much incase Murphy decided to show up. The next day I took the boat over to the fuel dock for a top off and pump out, the motor started within 10 seconds and everything seemed fine. I go to the boat last night to check all the fluids and to my shock I find evidence of Murphy's visit, the coolant reservoir was empty, and there did not seem to be much coolant when I took the radiator cap off. I made sure the coolant tank was filled with green coolant before we took her out. I also discovered I need to repack the gland as it is leaking two drips per second.
Here are my questions, with the most concerning to me first.
I did not smell anything, nor did I see any smoke, no alarms went off, and there does not seem to be any water in the oil, at least from looking at the dipstick, and the engage starts up just fine still, what possible damage could I have done if it ran without coolant?
How true is the statement that you can get an idea of problems by how easily the diesel starts and idles?
What mixture should I ensure to antifreeze and water for the freshwater cooling?
I have and am familiar with a volt meter, so how do I know or test that the engine overheat alarm is still functioning?
The PO installed a coolant temp gauge, which I don’t think works, with said volt meter how can I test that the senders are working or need to be replaced?
Since I am getting water in the bilge from the packing glad, is there a quick way to tell if the coolant leaked into the bilge? (and no I don't want to taste the bilge water to see if it tastes sweet
I hope to fill up the coolant tank tonight and attempt to spot the leak, if it is not as simple as a hose clamp, and I am not sure if the coolant leaked into the bilge, could the coolant somehow mix with the raw water and go out through the exhaust?
Is it possible that the coolant leaked into the hot water tank?
Thanks for all the responses in advance. Hopefully the problem will be something small and I haven't bit off more than I can chew.
