Go Back   SailNet Community > General Interest Forums > Gear & Maintenance > Diesel Engine Forum
Diesel Engine Forum This is a new forum dedicated to diesel engines and their applicable accessories.
Old 05-14-2011
jimd333sail is on a distinguished road
Frozen Head Bolts Universal 5411
I am doing a piston ring job on my Mod 15/5411 engine and half of head bolts are frozen and had to be broken off. There has been water fifteen years ago and the head bolts have been used before, it appears. I'm going to weld a washer and nut and hoping to break out the remaining part of the bolt without breaking it off. They are protruding from the block from 1/8" to 3/8"....I'm using heat and cold and vibration.
My question is this: if I have to drill and extract the bolts (especially if they break again below the block deck...I've been told that if your drilling is off more than a couple of thousandths, you might not get helicoils or threadserts to work. Is that true?
Does anyone know if there is a jig that can clamp onto the block to center the extractor? Also someone told me about a product called "Drill-Out Power Extractor". Anyone use that?
Thanks, Jim
Old 05-15-2011
tommays's Avatar
If the studs go into a wet part of the deck the helicoils tend to leak so its best to drill exact and save the hole
On my A4 gas after getting everything off i used the good holes to hold the head in place
Then got drill bits the size of the clearance hole in the head and drilled just a BIT to spot the hole and changed to the correct size bit
This was also a good way to guide the tap as they make extended ones
1970 Cal 29 Sea Fever
1981 J24 Tangent 2930
Tommays
Northport NY
Old 05-15-2011
I hadn't thought of using the cylinder head as a guide for centering the extraction process...will keep you posted, thanks, Jim
Universal 5411 Water Pump dbruce85 Diesel Engine Forum 1 05-05-2011 10:41 PM
Overheating Universal 5411 JohnBassett Gear & Maintenance 20 05-20-2009 11:54 AM
Universal 5411 gbertelsen Gear & Maintenance 2 05-12-2009 10:56 PM
Universal 5411 Oil Change saurav16 Gear & Maintenance 10 10-01-2007 07:16 PM
Universal diesel 5411 rmiille Gear & Maintenance 1 12-30-2001 06:01 AM
