Go Back   SailNet Community > General Interest Forums > Gear & Maintenance > Diesel Engine Forum
Diesel Engine Forum This is a new forum dedicated to diesel engines and their applicable accessories.
Old 05-22-2011
pras is on a distinguished road
ATF-A Equivalent Transmission Fluid
Hello All,
Does anybody know if Valvoline's Dex/Merc for engines requiring Dexron-III/Mercon is a valid substitute for ATF-A oil. My Yanmar/Kazaki specifies ATF-A; however, I can not find it around here and can't seem to find a simple answer.
Somewhere I remember reading Dexron III was an equivalent for ATF-A; however I can't find any evidence that it is the same.
Thanks in advance.
Old 05-22-2011
kd3pc's Avatar
kd3pc is on a distinguished road
ATF A is still available in most of Europe, and has been replaced in the US by Dexron
http://www.epc.shell.com/.../GPCDOC_...10942_1789.pdf or ATF - A Description - Kroon-Oil Gear Oils Automotive - Catalogue - Kroon-Oil
I found that I had some old original Dexron (no numbers or suffixes) and I used that in my Kanzaki gear box that was sticking in gear. It fixed it after two changes and some hours on the box.
I am told by the Shell Lubricants people that Dexron III is the replacement for ATF-A and that you can find the data sheets on line to compare specs.
The newer Dexron's (II, VI, Saturn, etc) are NOT the same and I can not suggest using them.
You may be able to find ATF-A at a "farm" or lawn mower shop as it is still used in some AG/Offroad applications.
Transmission fluid Billy654 Gear & Maintenance 2 01-18-2010 06:55 PM
transmission fluid DonStark Islander 2 09-01-2008 03:12 PM
Loss of all transmission fluid sailingwife Gear & Maintenance 4 01-03-2007 12:27 PM
Transmission fluid LaLeLu Gear & Maintenance 15 04-11-2006 09:24 PM
Transmission & Autopilot Fluid aphil138 Gear & Maintenance 0 07-24-2003 02:13 PM
