06-24-2011
Originally Posted by Bateau25
I agree with JimsCAL. The 5411 (and the M15) is unique in that it is directly raw water cooled without a heat exchanger and only one water pump.
According to the manual, water circulates thru the block and heads out to the exhaust manifold to cool down the exhaust ports and then thru the thermostat, if its open, and onto the exhaust mixing elbow, to the muffler and out the transom.
And what cools the exhaust gas into the elbow if the thermostat is not open?
If the thermostat is not open or only partially open, then most of the circulated hot water goes back to the mixing tee where it is supposed to mix with fresh cold water and then go thru the pump again for another cycle. Is this correct?
So the water that is headed for the thermostat is first heated by the exhaust manifold and opens the thermostat before the engine reaches operating temp? That is indeed unique. And by the sounds of it the raw water pump has engine temp (hot) water running over it most of the time? That must be good for the rubber impeller. Tell me it has a rubber impeller!!
Sorry Jim, I wasn't contesting your opinion just trying to add to it but then I'm obviously not schooled in the odd way that 5411 is engineered. Maybe I'll just withdraw from this discussion.
Arthur C. Clarke
