06-22-2011
Pool of oil under engine
Bringing back an Endeavour 32 after 7 years of neglect. After working on the engine for the last 3 months, I have had it running for short durations over the last month. It overheated after 10 minutes when I finally left the mooring. Cleaned all the marine growth out of the raw water intake and overheating was no longer an issue.
This past Friday, I again left the mooring for a short test cruise to ensure that the new stuffing box packing was succesful and stuffing box was running cool. I was only under power for about 20 minutes. A couple of days later, I was back on the boat and I noticed that there was about a quart of oil under the engine. No Sign of leaking anywhere that I could see.
Any suggestions on where I should start to look. I am planning to get some sorbant material from West Marine this week to clean up the mess and then run the engine again to see if I can identify the source. Both the engine and transmission were somewhat low. I admit that I should have checked them both more closely before I fired it up the first time.
I really hope I dont end up having to replace this engine or transmission. I have already replaced the Heat Exchanger, fuel pump, all fuel filters, oil filters, starter and all of the hoses.
The transmission dipstick was missing the washer, and would close properly. I put a rubber washer, but I don;t think it was quite the right size, since there was oil present after that last run. Is it possible that this amount of oil could have come from the transmission during that short amount of time.
Universal 5424 Engine
Hurth HBW100 Transmission
Thanks for any information....
Steve
S/V Island Fever
