Go Back   SailNet Community > General Interest Forums > Gear & Maintenance > Diesel Engine Forum
Diesel Engine Forum This is a new forum dedicated to diesel engines and their applicable accessories.
Old 06-24-2011
chuckg5's Avatar
chuckg5 is on a distinguished road
Question ford lehmin oil leak from air intake
we have an older rebuilt 3 years ago Ford Lehman 65Hp. problem is, oil leaks out of the side air intake filters and drips into the bilge. the engine has a hose from the oil cap to the air filters. I guess the splatting oil is suppose tobe sucked back into the engine with the air but the bottom of the sponge air filter is soaked with oil. Can I just bend the rubber tube coming from the oil cap back an stop the 'flow'? Do other engines do this?
Old 06-24-2011
That would be your crankcase vent.. if you plug it you may pressurize the crankcase and have more problems, esp if you're experiencing some blowby (possible if the vent is passing a lot of oil) Pressurizing the case could cause seals that are not leaking now to do so....
Can you reroute the hose to another area in the air cleaner/intake that will more likely 'suck' the drippings back into the engine?
1984 Fast/Nicholson 345
Old 06-24-2011
chuckg5's Avatar
great suggestion. I'm going down to her tommorow an will look to see if I can tube it further into the air intake.
thanks again!
chuck
Old 09-22-2011
Stevewlf is on a distinguished road
I've seen that problem in cars that had a crankcase vent hose coming off the valve cover. Pressure in the crankcase from ring blow by would be the first concusion. However, in my instance, it only happened after running at high RPM for 30min or so. Turned out that the oil being pumped into the oil passage in the valve train assembly was coming in faster than it could flow back to the crank case. In my case, the head gasket holes where the oil should drain back were under size (or had collected sludge) so I just cleared them out with a flat blade screw driver. Another possible cause, there might be an oil restrictor in the oil passage going to the head and that might have been left out when the engine was rebuilt. I've seen this in some auto engines and later found it in the bottom of the parts cleaner tank.
Anyhow, you can verify if you do have an oil flow back problem by carefully pulling the oil cap just after you come off an extended high RPM. To avoid hot oil spray, idle down and take a quick look inside and see if you see a flood of oil inside. The valve gear should be just wet with oil and only small pools in the recesses of the head and around the valves.
To cure the problem, take off the valve cover and probe the oil drain back holes for obstructions. If an oil restrictor is missing, then you will have to wait until the next top end overhaul.
My opinion, FWIW.
Steve
Old 09-22-2011
MacGyverRI's Avatar
MacGyverRI is on a distinguished road
see if the hose has a downwards loop that catches the oil and try to make it more uphill if that's the case.
Also look for other breathers and clean them out as they may be causing more back pressure that is pushing it to the air cleaner.
If you have way too much blow by, it may need a rebuild again.
Ken, East Prov., R.I. Bootlegger, PY26 Paceship
If you like my posts, or they were helpful, please click the "scales" icon on top right to add Rep points.
Old 09-22-2011
chuckg5's Avatar
Hi, an thanks
I like the idea of putting on a longer tube an loop it higher up in the engine room before going to the air intake. I'll try that this weekend. chuck:
Old 09-23-2011
MARC2012's Avatar
MARC2012 is on a distinguished road
Longer hose, catch in container.Seen this done on larger engines.Not a fix but less mess.marc
Old 10-30-2011
Capt Len is on a distinguished road
The injector return line is inside the valve cover on that model ??? If a washer or soldered fitting should fail, fuel goes into the lube oil .This is not good as you can guess. I've seen several run away by sucking oil into air intake when level in sump increases. If your injectors are outside the cover Ignore this info.
Old 10-30-2011
chuck53 is on a distinguished road
If you ever have problems with Lehmans, call American Diesel in Kilmarnock, VA and if you are lucky to get Bob Smith on the phone, you have reached the one person who knows more about Lehmans than anyone.
He can diagnose and tell you how to resolve problems over the phone better than most mechanics can sitting in your engine room.
This guy is basically the father of the marinized Ford Lehman.
Old 10-30-2011
chuckg5's Avatar
I buy parts from him quite abit. Next are engine mounts.
my model has the injectors on the outside of the valve cover, thankfully.
Manual for an old Ford Diesel long-way-from-home Gear & Maintenance 4 05-16-2010 09:34 AM
ford lehman 192d fcsob Morgan 2 12-23-2007 11:48 PM
ford lehman 192d fcsob Gear & Maintenance 1 12-11-2007 07:03 PM
Ford Lehman Engine TSteele65 Gear & Maintenance 3 04-06-2007 07:54 PM
Engine questions, Ford Lehman photojoe Gear & Maintenance 1 02-09-2007 11:13 PM
