06-26-2011
On the throttle cable on most Yanmars there is an idle adjustment and typically on most Yanmars the 'stop' control is a mechanical lever on the throttle cable that 'depresses' the idle setting below that which the engine idles thus stopping it .... this idle adjustment is usually on the starboard side of the engine between the trans and the engine block.
