07-05-2011
As nautich said, there's no telling.
SOMEtimes, a "wrong" colored fluid means an upgraded replacement, or a specialty part like "Royal Purple" oils, which are purple. If there is no fill label, no hang tag, no engine log note, a wrong color usually means "Gee, I can't find it, do we have any other oil on the boat?" and it could literally be olive oil for all you know.
Does it work or cause harm? Impossible to tell. Was it there to try hiding slippage or leakage? Impossible to tell. You have to consider the chance that the transmission will need to be removed and overhauled or replaced if the surfaces inside or seals have been damaged.
A truly conservative mariner, thinking about breakdowns in inconvenient places and times, would haul the tranny and send it out for a rebuild "period".
A more trusting soul might say "OK, we're going to put $800 in escrow because the tranny was not maintained properly. I'll buy the boat...but if I get a tranny failure, or a shop statement that it must be overhauled, withint the next 90 days, that escrow money gets applied to the transmission repair."
If the PO really did put something better in there...they'll let you know about it. Any other reply means yes, they did stick in the wrong oil and yes, it will need repairs somewhere down the line.
($800 being a random number for any kind of shop work.)
