Go Back   SailNet Community > General Interest Forums > Gear & Maintenance > Diesel Engine Forum
Diesel Engine Forum This is a new forum dedicated to diesel engines and their applicable accessories.
Old 07-25-2011
(Go Fast Sailor)
BayLAzr is on a distinguished road
Yanmar 1GM10 Overheating
I have a (1993?) Yanmar 1GM10 (single cylinder diesel) that gives an overheat alarm after about 10 minutes running at mid rpm. This has been a persistent problem and I've already done the following:
1) Flushed the cooling system with RydLyme (electrolyte descaler / cleaning flush - amazing stuff that every sailor should know about) which removed alot of scale and rust. I've done this flush several times now, and have done just about everything to get a thorough flush including both forward and reverse flow, even flushing with the impeller and thermostat removed.
2) Replaced impeller - and subsequent inspection shows that it is installed properly and not damaged.
3) Replaced all of the cooling system hoses and clamps.
4) Thermostat has not been replaced, but has no "guts". In other words, it is open all the time (more about this in a minute).
5) Removed exaust elbow and flushed / thoroughly cleaned - no restrictions there.
6) Checked the inlet / strainer and that's all good, too - plenty of inlet water flow.
Engine starts and runs fine and water is exhausting through the transom - not a whole lot of water, but a steady flow (I'm told these engines don't use a lot of water and based on the tiny impeller, suspect this is normal flow). I haven't checked the temperature of the exhaust water.
The bottom is clean and the (recently rebuilt, properly functioning, folding) prop is the correct size - plus I'm not running hard - usually mid rpm +/- 2500 rpm.
When flushing the system, I get good unrestricted flow in either direction (with impeller removed).
Soooo, I've put up with this for a long time because I normally only motor a short distance before and after putting up sails. Each of the efforts listed above seems to help some, sometimes for months, but eventually the God awful screeching high temp alarm returns. I even (temporarily) disabled the alarm, but know there is a problem and won't rest until its resolved.
Here are my questions:
Does anybody know if NOT having the guts in the thermostat could cause this engine to run hot (I know it could be a problem running cold in cold water / weather, but that's not my issue)? In other words, does a properly functioning thermostat in this engine somehow re-direct the water flow to force it into the head, and not allow the water to simply bypass as it would when the thermostat is closed? Or, is having no guts in the thermostat effectively the same as having an open thermostat? (FYI - this gutting the thermostat trick was done by a "mechanic" a couple years ago and I just discovered it - will likely replace it soon either way).
How likely is it that my temperature sensor is off a few degrees and is sending me on this "wild goose chase"? Is there any way to inspect / clean the sensor - or should it just be replaced? Does anyone know what the proper operating temperature of this engine should be (using it in salt / brackish water)? I'm thinking about using a temperature gun to measure the head temperature to test the sensor - anybody ever tried that / would it work effectively?
Last, but not least... Is it just time to throw in the towel and call a (real) mechanic for major $urgery / pulling head? And is that a sure fix?
1981 Pearson Flyer, 30', if anyone is wondering.
Anyway, I'm stuck and reaching out to the cyber masses for help! Regret the long post, but trying to answer basic questions on the front end... Thanks in advance for any experiences, help, or advice!
Bill
Old 07-25-2011
(Go Fast Sailor)
BTW - mine is the raw water cooled version...
Old 07-25-2011
mitiempo's Avatar
The proper temp for a raw water cooled engine is 140 degrees. Hotter than that and salt deposits build up rapidly. Fresh water cooled around 180.
I have a YSE-8 which is the predecessor to yours. My problem is it will not get up to temp and runs too cool.
Brian
Old 07-25-2011
JimsCAL's Avatar
JimsCAL is on a distinguished road
Sounds like you've done all the right things. Two comments.
1. Don't know how the cooling system on your engine is run, but the Universal 5411 on my previous boat would overheat if the thermostat was left out. The thermostat was needed to force water through the engine out the exhaust. Otherwise the water just recirculated and got hotter and hotter. Yours may be different however.
2. You may still have some blockage in the engine passages. Despite use of oxalic acid to clean the engine passages, I found 5 of the 8 plugged when I pulled the head on my previous 5411.
Old 07-26-2011
(Go Fast Sailor)
Thanks for the information. I'll put the temp gun on it later this week to see if I'm way over 140, plus put in the new thermostat and see if that helps.
If that doesn't do it, I'll rob my sail fund and pony up for a head job...
Old 07-26-2011
NCboatrx is on a distinguished road
Buy a thermostat and install it. This engine needs its thermostat. If there is no thermostat the cooling water will by pass the engine and just flow straight through to the exhaust causing the overheat alarm to go off.
Also check that there is no carbon build up near where the thermostat fits.
Stanley
Stanley,
Marine Diesel Engine Vendor
Old 07-26-2011
(Go Fast Sailor)
Thanks Stanley - will do! I'll let ya'll know what happens...
Old 07-27-2011
(Go Fast Sailor)
Bought a new thermostat and installed it today... We'll be able to test on the way out to the race course tomorrow night.
Looking at the thermostat and the installation I would say that the thermostat definately blocks the bypass flow and forces the cooling water through the cylinder and head - then out through the exhaust elbow.
I'm hopeful that this is the fix I've been looking for - fingers are crossed...
Old 07-29-2011
(Go Fast Sailor)
That did it!
Installed the thermostat and took her out last night - no overheating, no lights, no alarms!!! Wahooo!
Thanks
Tags
1 gm 10 overheating , 1gm10 overheating , yanmar 1gm10 , yanmar overheating , yanmar thermostat
Overheating Issues (1GM10) asdf38 Diesel Engine Forum 26 07-25-2011 03:16 PM
Yanmar 1GM10 Thermostat and Temp Sending Unit karluk Diesel Engine Forum 4 07-06-2011 06:13 PM
Loss of power on a Yanmar 1GM10? lawsonmitchell Diesel Engine Forum 5 06-14-2011 09:21 PM
Yanmar 1GM10 won't start Sometimesbrilliant Gear & Maintenance 12 05-10-2008 03:48 PM
Yanmar 1GM10 and racor fuel filter. SVDistantStar Gear & Maintenance 6 01-13-2008 11:17 AM
