Go Back   SailNet Community > General Interest Forums > Gear & Maintenance > Diesel Engine Forum
Diesel Engine Forum This is a new forum dedicated to diesel engines and their applicable accessories.
Old 07-31-2011
SawWhet is on a distinguished road
Diesel Fuel Gauge
We have a 1997 Beneteau 321 with a Yanmar 3GM30F -VDO fuel level gauge plus a combined oil pressure /engine hour meter
The fuel gauge is staying on the full mark all the time with no movement .
The gauge will show empty when key is turned off All connectors,fuse ect.at back of gauge are in good condition
Any suggestions as to what the problem is and where would I get spare parts if needed.
Thanks
Old 08-01-2011
MacGyverRI's Avatar
MacGyverRI is on a distinguished road
It could just be a bad connection, clean them 1st.
Next, could be a stuck swing arm on the float but that requires taking the sender out of the tank to check it.
Some gauge senders also use a "pulse" type power supply unit (works like a turn signal flasher) to get a reading and that could be bad if equipped w/ one. The boat elec. schematic would show it inline w/ the power supply.
Ken, East Prov., R.I. Bootlegger, PY26 Paceship
If you like my posts, or they were helpful, please click the "scales" icon on top right to add Rep points.
Old 08-01-2011
Maine Sail's Avatar
Your VDO gauge is likely a standard 240-33 Ohm unit. First measure your sender to see what the OHM reading is. Simply put your meter across the center pin and the aluminum top of the gauge to measure the resistance.
If the reading on the sender never changes, bad sender.. Any Teleflex fuel gauge should easily replace that VDO or you can get another VDO gauge. Most all, unless it is one of the European VDO senders & gauges use the 240-33 Ohm scale. The gauges simply read resistance.
If replacing the sender consider a mechanical with electric capsule or WEMA type as they FAR more reliable than the standard sending units.
______
-Maine Sail / CS-36T
Old 08-19-2011
Mad Bavarian
BigNige is on a distinguished road
My VDO sender is 3 to 300 Ohms, and the gauge reads full scale if the sender is disconnected.
Nigel
See new
- it's FREE!
Old 08-20-2011
JimsCAL's Avatar
JimsCAL is on a distinguished road
I agree with Mainesail. The vast majority of fuel gauge systems are as he describes. My guess would be the sender is since the gauge does read both full and empty. Disconnect the wires at the tank and measure the resistance with a DMM as Maine suggests.
Cat 42 fuel gauge problems Konaschultz Catalina 0 05-11-2010 06:10 PM
fuel gauge -- any suggestions? pegasus1457 Diesel Engine Forum 24 11-28-2009 03:01 PM
Fuel Gauge Morgan 30 Twoowls Gear & Maintenance 8 11-18-2009 02:02 AM
Fuel Gauge questions rikhall Gear & Maintenance 20 01-02-2009 10:22 PM
Fuel Gauge Problems trodzen Gear & Maintenance 14 09-05-2007 08:23 AM
