08-13-2011
Your original question was "what is an old diesel engine worth?" and you have gotten some good answers here. Let me add my two cents...
I have two 35 year old Yanmar 2QM15s. One was the original engine in my first sailboat. It is still in the boat, and running strong.
When I bought the boat 28 years ago, the engine looked nearly new, ran strong and was very reliable, starting quickly and responding quickly and fuel efficient.
A few years later my aluminum fuel tank rotted, and I didn't understand what was going on well enough to fix it until I had "dickered" with the engine and the tank and the fuel system for a couple of years. In addition, the exhaust elbow corroded and cracked and dripped salt water on the aft stbd motor mount for a few months...yeah, my fault, but I was working hard and almost never able to go to the boat to do anything other than make sure the bilge was relatively dry. Bottom line is, through my own neglect the engine became what I didn't want...unreliable and dirty and ugly.
I didn't really have the money to replace it with a new one, and I was embarassed that I had let the engine get in the condition it was in. I also knew there was nothing to lose and everything to gain if I could bring the engine back to order on my own, because I could do it again while I was out cruising. So I dug in...
Bought a tech manual, bought the parts to work on it, bought a fuel tank, pulled the engine, pulled the old fuel tank, put in a new fuel tank, did a mini-overhaul on the engine, put it back in the boat, and have a reliable, clean, responsive, economical engine again. Money spent on the engine was less than 300 bucks. Recently the fuel injection pump failed and that cost another 600 bucks, but that old engine was worth a lot to me, and still is, because I know I can do anything to it other than machining on parts that may need machining. I had never worked on a diesel engine before in my life. I used the manual and the internet, mostly forums like this, to learn, and I read and read. I made a few mistakes, and got a little advice from my friends.
My second engine I bought for 400 dollars from a fellow sailor who upgraded after he overheated the engine running back to harbor in severe weather and a small water leak developed past the head gasket into his engine compartment. I tore the top end down, replaced all the rubber parts on the engine, put all new gaskets and seals in the fuel system, put on a new head gasket, and put her back together. Ran her, and the head gasket still leaked. Parts to do that cost me about 200 dollars. Took the engine to a good machinist who did a head job on it including shaving the head. He also noted that the exhaust manifold was cracked in three places and plugged up pretty badly. He sent the manifold to a welder for me and reassembled the engine (I provided all the gaskets). Total cost was 350 dollars for that work.
I am installing this engine in my second boat. I expect it to give me at least 10 more years of service. This old engine was and is pretty high value to me.
New engine is probably nice, but it's nice to have an engine I know I can work on and maintain its reliability with a bit of expert help from time to time, at much lower cost than a new engine installation.
Good luck.
