Go Back   SailNet Community > General Interest Forums > Gear & Maintenance > Diesel Engine Forum
Diesel Engine Forum This is a new forum dedicated to diesel engines and their applicable accessories.
  #11 (permalink)
Old 08-18-2011
fryewe is on a distinguished road
If it were your exhaust, you would have black soot in your boat, especially in the engine room. If your engine room is painted white or off white, it would be obvious on inspection if you have an exhaust leak. Beginning to sound more and more, to me, like you have some insulation or foam that perhaps got wet with fuel, you have a small leak, or you have a fuel injector problem. Also, when the engine is running at higher rpm, the excess fuel that is pumped by the FI pump recycles back to the LP side of the fuel system (engine mounted fuel filter on mine). These lines may be the source of your leak. If you have a leak only at high rpm and it is seeping onto a hot engine surface, it might be evaporating due to the heat. Look for gummy deposits on the head and crankcase.
Soundproofing Engine Compartment Allanbc Gear & Maintenance 17 12-01-2010 03:06 PM
The smell of Diesel in the cabin, Oil Changes, & Engine Maintenence schedules LittleWingCA General Discussion (sailing related) 26 11-16-2010 04:35 AM
Water in engine compartment nightsky Gear & Maintenance 17 09-25-2010 06:40 AM
Noisy Engine Compartment Fan sun37 Gear & Maintenance 10 03-21-2008 07:27 AM
Smoke in W60 engine compartment pma_foyl Gear & Maintenance 2 07-01-2004 08:58 AM
