Go Back   SailNet Community > General Interest Forums > Gear & Maintenance > Diesel Engine Forum
Diesel Engine Forum This is a new forum dedicated to diesel engines and their applicable accessories.
Like Tree4Likes
  #11 (permalink)
Old 08-17-2011
emoney's Avatar
emoney is on a distinguished road
Ouch, I think that prop (and shaft for that matter), MIGHT just scratch your leg if you go near it...lol. Little critters get into everywhere. Buy hey, I need to go under mine this weekend as I fear the same sight.
  #12 (permalink)
Old 08-17-2011
MacGyverRI's Avatar
MacGyverRI is on a distinguished road
Originally Posted by emoney View Post
^this, is a great thought. Very easy to check; grab a snorkel mask and jump in. Also, simple to solve too. Hopefully this is the case. I would suggest, however, that in the future you think about installing a temp gauge. By the time the "smoke billows", it can be way too late. Just a though. Good luck.
Most times the thru hull is reachable from hanging over the dock, if not just a mask and holding your breath.
Use a steak knife sideways and on an angle (pulls the critters out) to clear it out. The strainers will catch anything that stays loose inside.
Ken, East Prov., R.I. Bootlegger, PY26 Paceship
If you like my posts, or they were helpful, please click the "scales" icon on top right to add Rep points.
  #13 (permalink)
Old 09-02-2011
wescarroll is on a distinguished road
If you are getting water out the exhaust in an amount consistent with your boats history it is unlikely a raw water supply problem. Check the coolant thermostat and clean out the heat exchanger, check the coolant pump and belts. Generally a fouled prop will cause overheating only in a system that is having or about to have other problems, as it has little effect of the cooling systems ability to remove heat.
overheating M25 BarryL Diesel Engine Forum 5 06-12-2010 08:28 PM
overheating ??? DennisKrotzer Islander 2 07-26-2009 10:09 PM
Overheating HELP !!! Culinary411 Gear & Maintenance 19 08-07-2007 05:33 PM
Yanmar 2GM overheating Northeaster Gear & Maintenance 11 07-18-2007 03:07 PM
perkins 4-108 overheating lisevp Gear & Maintenance 1 01-29-2003 01:38 AM
