Go Back   SailNet Community > General Interest Forums > Gear & Maintenance > Diesel Engine Forum
Diesel Engine Forum This is a new forum dedicated to diesel engines and their applicable accessories.
Like Tree4Likes
Old 08-16-2011
epaolino's Avatar
Rapscallion
epaolino is on a distinguished road
Overheating M35-B
I was wondering could a fouled prop cause overheating?
Took the boat out after an extended period at the dock to have a riser pipe installed. I felt the prop was fouled as we moved forward ( seemed sluggish ). Worked ok in low rpms. Plenty of water coming out of exhaust. warmed up and pushed past the no wake zone... in about a mile...over heating, blaksmoke and steam. I shut it down, check the antifreeze, ok checked oil, ok. let the engine cool a little, restarted water coming out exhaust, cooled down to normal. Kept it below 1500 limped back to the slip. Checked the raw water stariner, clear Ok, Checked Impeller, Ok no broken vanes.
Could it really be just a badly fouled prop?
Old 08-16-2011
MarkSF is on a distinguished road
Interesting, as mine behaved exactly the same yesterday. It was fine heading out at 2K rpm, but on the way back the temp started to rise until it hit 190. At that point I throttle back to 1400rpm and the temp dropped right down.
Haven't checked the strainer yet though.
But in answer to your question, I think it could cause overheating yes.
epaolino likes this.
Bristol 31.1
Old 08-16-2011
epaolino's Avatar
Rapscallion
Thanks for the reply mark....
I thought that a fouled prop would act like a "freewheeling" prop with no bite and would do no work.
Old 08-16-2011
emoney's Avatar
emoney is on a distinguished road
I'm no expert, but I'd think a fouled prop might show other signs/symptoms as well??
What about the "cooling pump" (I may be misnaming this part) that's belt driven on the top-front of the engine? Is your drive belt tight enough? Just throwing out suggestions.
Old 08-16-2011
epaolino's Avatar
Rapscallion
The belt driven engine water ( antifreeze ) pump, checked belt tension and is not leaking. Raw water pump impeller is intact and ok.
Old 08-17-2011
MacGyverRI's Avatar
MacGyverRI is on a distinguished road
It could have algae or barnacles on the through hull (usually a slotted intake) restricting the flow.
Ken, East Prov., R.I. Bootlegger, PY26 Paceship
If you like my posts, or they were helpful, please click the "scales" icon on top right to add Rep points.
Old 08-17-2011
eherlihy's Avatar
Finally found the needle!
eherlihy is on a distinguished road
The answer to your question;
is YES.
Growth on the prop adds to the drag. Depending on how much growth, it could require SUBSTANTIALLY more torque to spin the prop at a given RPM. The prop could even be restricted by growth.
Think of it as if you were towing a heavy load with your car. The engine has to work much harder to accomplish the same amount of work.
ASA 101/103/104/105 Certified - Also certified in Recreational Marine Electrical Systems
Old 08-17-2011
emoney's Avatar
^this, is a great thought. Very easy to check; grab a snorkel mask and jump in. Also, simple to solve too. Hopefully this is the case. I would suggest, however, that in the future you think about installing a temp gauge. By the time the "smoke billows", it can be way too late. Just a though. Good luck.
Old 08-17-2011
epaolino's Avatar
Rapscallion
Bottom kind of clean.... Prop loaded!
Old 08-17-2011
epaolino's Avatar
Rapscallion
Good Point.
Temp gauge is at ankle level....was hot enough to wiff some steam not hot enough to trigger hi temp alarm... I need to double check the alarm...
overheating M25 BarryL Diesel Engine Forum 5 06-12-2010 08:28 PM
overheating ??? DennisKrotzer Islander 2 07-26-2009 10:09 PM
Overheating HELP !!! Culinary411 Gear & Maintenance 19 08-07-2007 05:33 PM
Yanmar 2GM overheating Northeaster Gear & Maintenance 11 07-18-2007 03:07 PM
perkins 4-108 overheating lisevp Gear & Maintenance 1 01-29-2003 01:38 AM
