Go Back   SailNet Community > General Interest Forums > Gear & Maintenance > Diesel Engine Forum
Diesel Engine Forum This is a new forum dedicated to diesel engines and their applicable accessories.
  #11 (permalink)
Old 09-02-2011
fryewe is on a distinguished road
I wouldn't use RTV. The gaskets will do the job well unless you have eroded sealing surfaces. Looks like you have all the gaskets listed. Don't you need two zincs (fore and aft)? Zinc packing is copper washer, and usually reusable, but they're inexpensive so I would replace both. Soot in the manifold and exhaust elbow are not a problem, unless it is a very thick coating. It will build back up quickly. You need to run up the engine each time you run it, especially before shutdown for a minute or two, to blow any soot out.
If you were able to dig out and flush out the manifold well, and water is flowing freely through it while it is off the engine, you probably have solved your problem.
  #12 (permalink)
Old 09-02-2011
JimsCAL's Avatar
JimsCAL is on a distinguished road
Agree about not using RTV. Permatex makes several products for coating gaskets to improve sealing. Check your local auto parts store.
Tags
2qm15 , diesel , overheating , raw water , yanmar
Yanmar 2QM15 Overheating at Idle... backcreeksailor Gear & Maintenance 27 08-29-2011 02:56 PM
yanmar 2qm15 fuel problem pfirth Diesel Engine Forum 11 05-11-2011 12:23 PM
Yanmar 2qm15 fuel problem pfirth Diesel Engine Forum 10 04-09-2011 01:20 AM
Yanmar 2QM15 raw water pump problem menado Gear & Maintenance 3 07-23-2008 02:20 PM
Yanmar 2QM15 Problem shipley Gear & Maintenance 5 05-18-2001 09:17 PM
