09-06-2011
Señor Member
Originally Posted by stantale
Thank you for the answers, very helpful!
This is the sequence for the football: it's all in a straight line, so water comes in through thruhull, through seacock, into the newly found strainer, into the bottom of the football, exits the top via a 90" adapter on which the rubber hose attaches which goes straight to the engine.
There seems to be a drain hole on the side (visible in the picture) or at least its a nut that is centered on the football.
There is also that black wire that is cut and just hanging down, I assume it's just a grounding wire.
Any new guesses?
If no one knows, I'll remove it - or just leave it and call it the football, raising my eyebrows ominously when someone asks about it.
Stan,
At this point, I think it safe to say that you probably don't need the football.
Here's a thought: Close the seacock and remove the (drain plug?) nut on the side to see what you find. It could be just a sacrificial anode/pencil zinc, located there for some reason that made sense to someone at one point. Since the grounding wire's not connected to anything, it's serving liittle purpose now.
