09-09-2011
Help me diagnose this...
Went out on my 84 catalina 27 w/ universal m18 diesel today. After a couple of hours of motoring, my RPMs seemed to drop significantly at max throttle. While I normally get about 3000 at full throttle, i now seemed to max out at about 2200. It also stalled out when I brought the throttle all the way back, so I'm pretty sure it's not a problem with the throttle cable or lever
Also, although I didn't put 2 and 2 together until several hours later, I did note a very strong exhaust smell it the cabin; strong enough that I opened a hatch to vent it out.
Here's what I am thinking....
Water sucked up through the exhaust. The flap on my thru-hull is missing, and although there were no following seas (it was dead calm), perhaps water was sucked back up from the wake of passing motor boat if my anti-siphon valve is clogged.
Does this explanation fit?
If so, do I now have water in my cylinders?!?!?!??!
I would think that if water did get that far up, I would have 0 RPMs.
