Go Back   SailNet Community > General Interest Forums > Gear & Maintenance > Diesel Engine Forum
Diesel Engine Forum This is a new forum dedicated to diesel engines and their applicable accessories.
Old 09-11-2011
MatthewM is on a distinguished road
Volvo Penta 2020 Starting Trouble
Hello all,
I have a Volvo MD2020 inboard diesel and am having trouble. The engine was new in 2005, has had regular use and maintenance. The engine has always started up immediately, without any trouble. Today the engine would not start. I go through my starting sequence, including 10-15 seconds of glow plugs, and it turns over normally but will not fire and run. The only thing that I have done since the last time the engine was started was add 5 gallons of fuel.
This is the troubleshooting I have done.
-Engine stop in
-Re-bled fuel line, making sure that fuel was getting to the injectors.
-Checked fuel filter
- Checked air filter
The engine is getting fuel and air, and the compression sounds good. A couple of weeks ago I tried starting the engine with the engine stop pulled, and this is exactly what the engine sounds like now. After my trouble-shooting it seems like there something that is keeping the engine from firing, but after inspecting the engine stop I can find nothing that would cause that. Is it possible there is a blown fuse, or something else going on. Any ideas would be greatly appreciated.
Thanks
Matthew
Old 09-11-2011
Hartley18's Avatar
Termite Fodder
Hartley18 will become famous soon enough Hartley18 will become famous soon enough
Matthew, if it were a blown fuse, the engine simply wouldn't crank.
You've not mentioned anything about glow plugs. How long do you leave the glow on for before you try to start the engine??
Crew member on the Womboat for:
2011 Heaven Can Wait 24Hr - Race against Cancer.
Old 09-11-2011
Sorry,
I let the glow plugs heat for 10-15 seconds. I will edit my original post to add that. I would like to believe it was the glow plugs, but they seem to be working and I have not altered my starting sequence.
Thanks for the reply Hartley
Matthew
Old 09-11-2011
Hartley18's Avatar
Termite Fodder
Unlike many other makes, for some reason the Volvo MD2000 range really need glow to get going. If you're having trouble starting, 10-15 secs is a bit light on.. try 30 secs instead.
My guess is that your glow plugs are not getting enough power. Check that the control panel negative connection is not corroded:
http://www.sailnet.com/forums/diesel...on-switch.html
Something worth checking, anyways.
Cummins 903/Volvo Penta QuickMick Gear & Maintenance 0 03-18-2010 12:02 PM
Volvo Penta 39 jernhenrik Gear & Maintenance 0 10-18-2009 12:00 PM
Trouble Starting my Yanmar 1GM bullrunner Hunter 2 11-14-2007 03:06 PM
Trouble Starting my Yanmar 1GM bullrunner Gear & Maintenance 3 04-25-2007 04:16 AM
Volvo/Penta MD7A paulinet. Gear & Maintenance 1 11-26-2001 01:50 PM
