We are not talking about a small diesel pump. A small diesel pump does thousands of gallons per hour.
It is the COOLING water pump of a small diesel, the one that is responsible for the splosh-splosh-splosh sound of the exhaust. I would guess a quarter cup per splosh, below 200 gph. Maybe a bit more at higher revs, but still lame compared to ONE $20 bilge pump, which does 500gph. If you want to be more scientific than splosh math, just look at the hose diameters. Hose barb inner diameter, to be precise. The result is the same.
However, the main point is no that the cooling pump is a Mickey Mouse pump, but that it is
important: With the setup you recommend, one is likely to loose the engine at the worst time, i.e. when there is water in the boat, because all kinds o stuff will be floating around to clog the pump. And that I know, surefire, from experience.
Not from sinking a boat, just from thoroughly hosing the inside of one down with a garden hose:
The "seawater filling the hull" is not "crystal clear", because it brings up whatever it finds under the floor boards and behind the inner liner of the floor. (Which was the reason for the hosing)
LONG before "your batteries go under" you have hundreds of gallons of water in the boat, by the time "your auxiliary power is partially submerged" we are talking thousands of gallons. These numbers I know, surefire, from simple calculations. Floor area times height of battery top is a good enough approximation, if you care to check that.
I you need to "pull a hatch" to notice THAT much water in the boat, uh-oh.
In that situation, yes, the few gph from the cooling water pump are worthless. But loosing the engine, and thus power to run your electric pumps, just because the cooling water pump chews up an old napkin, a few Cheetos, and one pea, would be a major bummer, wouldn't it?
Oh, and your "commercial guys out on the water for months at at a time " don't hang out there on 27 foot sailboats with 13hp diesels. Their cooling water pumps probably won't die when fed a napkin.
Btw., I wonder what they are doing out there that long? Lighthouse wardens? A container ship goes around the world once or twice in that kind of time.
But still, nice rhetoric.
Originally Posted by apogee1mars
You sound like you know what your talking about. "Surefire way" is it? Hmmm. I guess all those commercial guys out on the water for months at at a time should have read the book. So just how many GPM does a small diesel pump?
How many GPM is worthless discharge in the advent of a breach. Have you ever pulled a hatch and observed the crystal clear seawater filling the hull, watching your batteries go under as your auxiliary power is partially submerged? I am guessing not. I hope it never happens to anybody, but unfortunately it does happen.
