09-26-2011
Any hardware store will have bolt extractors, they are a spiral tapered bit of square stock sized to the bolt you are trying to remove with a left hand (counterclockwise) twist, you drill a small hole, tap this into the hole and turn it out with a tap handle or crescent wrench if space permits. The old left hand drill bit in a slow speed cordless drill works well too, but I would try the slot cutting and flat blade screwdriver mentioned earlier first
