Go Back   SailNet Community > General Interest Forums > Gear & Maintenance > Diesel Engine Forum
Diesel Engine Forum This is a new forum dedicated to diesel engines and their applicable accessories.
Like Tree2Likes
  • 1 Post By Hartley18
  • 1 Post By erps
Old 09-27-2011
jackdale's Avatar
jackdale will become famous soon enough
Decompresssion levers
Do any modern diesels have decompression levers?
A buddy and I were talking tonight about this. I have started engines by decompressing cylinders and using a weak battery to get the engine spinning.
So how do we start a reluctant engines these days?
ISPA Yachtmaster Offshore Instructor Evaluator
CYA Advanced Cruising Instructor
Old 09-27-2011
Hartley18's Avatar
Termite Fodder
Hartley18 will become famous soon enough Hartley18 will become famous soon enough
AFAIK, you call a Diesel Mechanic..
Not only don't modern diesels have compression levers, but most of the really fancy new ones have electrical systems (common-rail injection, etc.) that absolutely MUST be working to get the engine going.
Having said that, a modern diesel is a pretty reliable beastie - but it is getting to the point where, if it doesn't start, there isn't much you can do about it without the computer diagnostic tool and a degree in error codes..
Just one more reason not to get hit by lightning.
jackdale likes this.
Crew member on the Womboat for:
2011 Heaven Can Wait 24Hr - Race against Cancer.
Old 09-27-2011
erps's Avatar
the pointy end is the bow
Our 1989 Catalina 34 with the Universal XP25? had a decompression lever and I even had to use it once.
I've heard that some folks carry one of those little portable jumpstart battery packs in their boat in case their starting battery goes dead.
Ray
S.V. Nikko
1983 Fraser 41
La Conner, WA
Old 09-27-2011
jackdale's Avatar
Is a "check engine" light next?
Old 09-28-2011
PorFin's Avatar
Señor Member
PorFin is on a distinguished road
If the marine industry is following other sectors -- probably so.
My initiation into diesel engines began with big puppies -- we're talking about the power plants in Army tracked vehicles and cargo trucks. Decompression levers were not in the mix. Old school mechanics were relied on listen, observe and then diagnose what ailed sick engines.
That is not the norm today. Over the years, and for a variety of factors (streamlining manning levels among them), the paradigm shifted in a subtle but significant way. We went from actually troubleshooting and fixing the engines to just pulling various bits and replacing them (then sending the offending parts back for repair at a higher level of maintenance.) It was usually quicker and more efficient. This drove the design of power plants towards providing for interface with computer diagnostic equipment that would accurately ID the malfunctioning part. And as you might guess, that "check engine" idiot light became the canary in the coal mine so to speak.
Old 09-28-2011
Hartley18's Avatar
Termite Fodder
I hate to say this but we're there already.. Go have a look at one of those fancy new stinkpots floating around your local marina.
There'll be a yellow flashing light somewhere near the ignition switch. Number of flashes indicates the fault code..
Sophus Berendsen Easy Locke clutch replacement levers fieldsson Gear & Maintenance 5 03-02-2012 07:33 AM
