10-19-2011
Clearances
Those little raw water rubber-impeller pumps must have a decent end-plate seal -- on both sides of the impeller.
I had to have one outer end plate(cover plate) lapped to get some grooves out of it to restore some suction to our Oberdorfer pump. Later I had to replace the whole pump. Unlike the old pump design with its paper gasket, our newer one also has the O-ring on the plate, FWIW.
Our local water carries a higher load of fine abrasive silt due to the Columbia flowing thru hundreds of miles of basalt formations. That fine "sharp" silt will enlarge the cast pump chamber over time and reduce the suction.
Other waterways may put far less "wear" on their pumping systems. So "YMMV."
OTOH, it's one more factor to consider when planning for preventative maintenance on your engine.
So, how is the water composition where you operate your diesel?
Regards,
L
ps: Plus One on the comments from MM2187, also.
