Go Back   SailNet Community > General Interest Forums > Gear & Maintenance > Diesel Engine Forum
Diesel Engine Forum This is a new forum dedicated to diesel engines and their applicable accessories.
Old 10-26-2011
aa3jy is on a distinguished road
Crush Washers
Is there a particular way crusher washers are facing when replaced on the fuel low pressure side of a diesel? I noticed that most crusher washers have a flat side and a somewhat rounded side..is there a reason for that..can't find any references to that question.
Old 10-26-2011
kd3pc's Avatar
kd3pc is on a distinguished road
the curved or dimpled side should go to the bolt or nut side that is applying the tension to the joint, the thought being that spreading out that torque should apply equal pressures to the entire joint...
they are single use, and quite critical to the long term function....
Old 10-26-2011
Your reasoning sounds correct..do you have a reference that I can verify?
Old 10-26-2011
kd3pc's Avatar
none whatsoever....I even have people tell me they are not needed at all...and they throw them away, or ....worse
this is from years of working on fuel systems (and other car/MC, heavy equipment) that use them and the side affects/cost of not using them.
You can google Belleville (sp) washer to see the theory (and the inventor) behind them and most pictures indicate the bell to the bolt side...that was the acronym that I used way back when I learned FI systems....
YMMV
Old 10-26-2011
Looked at Bellevue Washer site..they refer to spring washers..Basically what I have are flat copper washers with a some what of a rounded face on one side and a flat face on the other..but both sides are basically flat as compared to the Bellevue spring washer..I guess the same principle applies.
Old 10-27-2011
Capt Len is on a distinguished road
These washers can be annealed for reuse if necessary but you should carry spares anyway. I've spent enjoyable time searching in the bilge because the owner didn't. Especially true for injectors.
Old 01-12-2012
luck66 is on a distinguished road
Wish I had this information a few years ago when I was having trouble bleeding my fuel line. Got new washers, all works good now. I now have spairs.
New crush -- Ensenada 20 bobmcgov Boat Review and Purchase Forum 7 10-09-2011 06:37 PM
How Crucial are Washers? Harborless Gear & Maintenance 9 08-26-2011 01:50 PM
Pressure Washers RhythmDoctor Gear & Maintenance 29 08-20-2011 11:36 PM
Diesel 'Crush Test' aa3jy Diesel Engine Forum 19 11-25-2010 07:31 AM
Annealing Copper Washers W.Ritchie Gear & Maintenance 1 08-31-2001 08:13 AM
