11-08-2011
diagnose fuel pumps
Fuel issues in my Yanmar 1GM10.
It began 'sagging' at cruising speeds several weeks ago. Throttle behavior is normal up to 2000 rpm. Above that it starves and loses power and rpms. It can rev higher, all the way to 3000 for a moment when the throttle is opened wide, but there's no power and it dies quickly.
To date I have replaced primary sand secondary filters, the lift pump and the injector. Bled and bled and bled.
When hand cranking with the compression released, I can hear the injection stroke. It used to be a short, defined pop sound. Now it's a longer squirting tone that rings in the delivery pipe.
Has my high pressure pump gone wimpy? Do we dare rebuild or just buy the unit? Could there be Governor issues? How bout a cheap little spring to replace?
Thanks.
