11-14-2011
If the head is made of aluminum, cracks are almost guaranteed to exist. Cast iron takes overheating, but not aluminum. By the way, you can weld aluminum heads; however, finding a shop that knows how is a problem and you do not want a crack repair to open up on you when you really need the engine. If you have a crack, exhaust gets into the water jacket and acts like overheating because the exhaust acts like steam sort of. Anyway, get a test kit for exhaust gas in the radiator from an auto parts store and test. It might be that you had a crack in the first place because it took a while for the light to come on. However, you did say you have run the engine for a season so a crack would show coolant in the oil by now.
