Go Back   SailNet Community > General Interest Forums > Gear & Maintenance > Diesel Engine Forum
Diesel Engine Forum This is a new forum dedicated to diesel engines and their applicable accessories.
Like Tree5Likes
  #21 (permalink)
Old 12-01-2011
SloopJonB's Avatar
Senior Moment Member
SloopJonB will become famous soon enough
Originally Posted by bassviking View Post
Now I think I have a jacked up transmission. Goes in reverse just fine but doesn't fully go into forward. Shaft just turns real slow in forward no matter the RPMs Ain't boat ownership awesome.
Good deal on the noise. The gear situation sounds like a simple cable adjustment.
"There is nothing, absolutely nothing, half so much worth doing as simply messing about in boats". The Water Rat from The Wind In The Willows
Sailing for 40 years in the Pacific, Atlantic, Caribbean but mostly Georgia Straight.
Currently own a Columbia 43.
  #22 (permalink)
Old 12-04-2011
Rockter will become famous soon enough
Try charging the battery fully. Sounds like you have an alternator belt that may be a bit loose and is trying to re-charge a discharged(?) battery.
You will not have wrecked the motor in that time. Engines starved of lube do not screech immediately. They rattle, and it gets louder, and louder, then they make a whine and a screech as the pistons sieze.
Been there, heard that.
Watch very carefully the banjo fitting that is on the aft end of the oil-line that runs from the oil filter to the governor area. That banjo is notorious for blowing off, and pumping all your oil into the bilge. It needs re-soldering. So far, it's happened to me twice. Be careful. Watch it.
Rockter.
Name Change theartfuldodger General Discussion (sailing related) 12 07-22-2009 01:22 PM
Cutlass change trantor12020 Gear & Maintenance 4 09-17-2008 09:02 AM
What would you change?? Giulietta General Discussion (sailing related) 66 02-01-2008 08:49 AM
Best oil change pump bestfriend Gear & Maintenance 12 05-19-2007 08:21 AM
Loose Change GotTheNotion General Discussion (sailing related) 13 05-07-2007 02:32 PM
