11-29-2011
Senior Moment Member
Originally Posted by ggray
All right now. Is it really necessary to fill the filter?
I've always done it, but after thinking about it a few years ago, I'm not convinced you do. Does oil flow under full pressure thru the filter before it flows to the critical lube points? I would think it flows through the engine passageways first, and then goes thru the filter, in which case, filling the filter first shouldn't matter.
But I've been wrong before, so what's the consensus?
I'm only intimately familiar with the Chevy small block and in that engine the pump pushes through the perimeter of the filter, through the media and up the middle of the filter into the oil galleys. I suspect that is the usual path so clean oil is always being pumped but I'm not sure which way it gets pushed from the pump in your Volvo. No matter which direction it flows, an empty filter is going to have to get filled. If the engine is running it's going to get something akin to an embolism - a period of starvation while the filter fills up - it usually takes about 20% of the total volume in the filter. You can check it on any given engine quite easily. Start an engine before the change and see how quickly it builds oil pressure. Change the oil and filter without filling the filter and see how long THAT takes to build pressure. If it is noticeably longer, it pushes through the filter first. If it takes the same time as previously, you should see a dropoff in pressure shortly after the engine is running while it fills the filter.
"There is nothing, absolutely nothing, half so much worth doing as simply messing about in boats". The Water Rat from The Wind In The Willows
Sailing for 40 years in the Pacific, Atlantic, Caribbean but mostly Georgia Straight.
Currently own a Columbia 43.
