12-01-2011
If it's the intake between hull and the pump you have to be particularly careful as this has suction on it so is more prone to collapsing. I bought mine from a proper marine chandler, they sell heavy-duty wire-spiral-reinforced stuff. Recommend doubling clamping it too.
Even the pipes from pump to heat exchanger, and from exchanger to exhaust, are pretty important as failure of them with the seacock open could sink the boat.
Bristol 31.1
